Copy https://user:pass@server/file flash: Fails
sotiris.ioannou
Hi all,
I'm trying to copy a file from using copy https://user:pass@server/file flash: . Credentials are correct and I can download the file using http, but everytime I use https I get the following error
debug ip http all
http_client_abort_request:
http_client_abort_request: Bad Transaction Id
Any ideas why this is happening, the http server is apache2 and it has a self signed certificate.
Sotiris
Richard Burts
I wonder if the issue is the self signed certificate. If you do https in your browser to a server with a self signed certificate you will get a warning message and you have an opportunity to accept it. I wonder if the router is seeing the warning and has no way to ask you whether you want to accept it or not.
Rick
Rick
Hi Rick,
I can see the Cisco replying back with a Bad Certificate message and then a tear down of the connection. I will give it a go with public certificates and go from there.
Sotiris
