copying(tftp) startup-config from one router to another
akobwaycct
hi
i know its possible to copy an ios image form one router to amother using one router as a tftp server and another one as a client.
Now i want to copy the starup-config of one router to another router.i tried the following but does not seem to work.
from i router i did the following
tftp-server nvram:startup-config 1
access-list 1 permit 10.0.0.0 0.255.255.255
end
and then i tried the following but still ddnt work
copy startup-config tftp
hostname:10.x.x.x
destfile name :xxxxxxx
these two did not work
can anyone give me an idea of how to do this.the two routers can ping each other and i can telnet from one router to another
kerek
Level 4
Level 4
Try to make "debug tftp packets" on the destination to see what is happening.
Krisztian
milan.kulik
Level 10
Level 10
IMHO you should have used
copy tftp startup-config
from the second router.
If doesn't work, why don't you use some tftp server on your PC (free 3CDeamon, e.g.) and download it to your PC and upload from it to the second router then?
BR,
Milan
