Correct cable??
jo.keunen
hi
I've recently installed a cisco 2811 with a VWIC2-2MFT-T1/E1 card.
BT is providing me:
Electrical Interface: G.703
Physical Connector: BNC 75 ohm unbalanced
I have already ordered a CAB-ADPT-75-120 adaptor cable. Now my question is:
what cable do I need to connect my router to the NTE / Adapter?
Thanks in advance!
paolo bevilacqua
You don't need the adapter. You only need CAB-E1-RJ45BNC and configure "line-termination 75-ohm" under controller e1.
well yes, I found that out AFTER i ordered the adaptor...
anyway as I have the adaptor now, what cable do I need to use to connect it to the router?
Thanks in advance!
Hi, the correct cabling is what I've indicated before.
i've found what i need:
CAB-E1-RJ45NT=
or a RJ48C pinout. (pin 1,2,4,5)
i've made a STP cable with this pinout and it works.
the advantage with the adaptor is that I can make a custom length cable.
