Correct/Incorrect configuration of CISCO Router 877
Hello all,
I do not have much experience with configuring CISCO Routers, but I had to try configuring it.
Below is the output from Show Run command, please check below and let me know if anything is missing or if I need to adjust things in a correct way.
blue#show run
Building configuration...
Current configuration : 2341 bytes
version 12.4
no service pad
hostname blue
boot-start-marker
boot-end-marker
logging message-counter syslog
aaa new-model
aaa authentication login VPN_XAUTH local
aaa authentication login LOGIN local
aaa authentication enable default enable
aaa authorization console
aaa authorization exec LOGIN local if-authenticated
aaa authorization commands 15 LOGIN local if-authenticated
aaa authorization network VPN_GAUTH local
aaa session-id common
dot11 syslog
ip source-route
ip cef
username XXX privilege 15 password 0 XXX
archive
 log config
  hidekeys
interface ATM0
 no ip address
 no atm ilmi-keepalive
 pvc 8/48
  pppoe-client dial-pool-number 1
 dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template1 type tunnel
 ip unnumbered Dialer0
 ip nat outside
 ip virtual-reassembly
 tunnel mode ipsec ipv4
interface Vlan1
 ip address 10.0.1.1 255.255.255.0
 ip nat inside
interface Dialer0
 no ip address
interface Dialer1
 ip address negotiated
 ip mtu 1380
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp pap sent-username XXX password 0 XXX
ip local pool VPN_IP_POOL 10.0.4.10 10.0.4.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 101 interface Dialer1 overload
ip access-list extended VPN_ACL
 permit ip 10.0.1.0 0.0.0.255 10.0.4.0 0.0.0.255
access-list 23 permit 10.0.4.0 0.0.0.255
access-list 23 permit 10.0.1.0 0.0.0.255
access-list 100 permit tcp any any range 49152 65535
access-list 101 deny   ip 10.0.1.0 0.0.0.255 10.0.4.0 0.0.0.255
access-list 101 permit ip 10.0.1.0 0.0.0.255 any
access-list 101 permit ip 10.0.4.0 0.0.0.255 any
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 access-class 23 in
 exec-timeout 0 0
 privilege level 15
 login authentication LOGIN
 transport input telnet ssh
scheduler max-task-time 5000
end
blue#
17 Replies 17
Julio E. Moisa
I see several configurations for different targets, NAT, VPN, PPP.
The NAT configuration looks fine, you could use the standard ACL 23 instead the ACL 101, this line could be removed: access-list 101 deny   ip 10.0.1.0 0.0.0.255 10.0.4.0 0.0.0.255.
My recommendation is use a standard VLAN instead extended VLAN.
Now you could remove the following line:
 ip nat outside
But Im not sure the reason to use this router, could you please provide more details?
Thank you in advance.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Currently, I have two CISCO Routers series 800. One of them is 887VA, the other one is 878.
The first 887VA router has the below configuration:
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.200 192.168.1.255
ip dhcp pool DHCPSRV
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server XXX
interface ATM0
 no ip address
 hold-queue 224 in
interface ATM0.1 point-to-point
 snmp trap link-status
 pvc 8/48
  dialer pool-member 1
  protocol ppp dialer
interface Ethernet0
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip nat inside
 ip virtual-reassembly in
interface Vlan1
 ip nat inside
 ip tcp adjust-mss 1452
interface Dialer0
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp authentication pap callin
 ppp pap sent-username X password 0 X
 ppp ipcp dns request
 ppp ipcp wins request
 ppp ipcp route default
 no cdp enable
ip local pool VPN_IP_POOL 192.168.4.70 192.168.4.99
ip http server
ip dns server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 192.168.1.253 80 interface Dialer0 80
 permit ip 192.168.1.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.4.0 0.0.0.255
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 101 deny   ip 192.168.1.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 101 deny   ip 192.168.4.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.4.0 0.0.0.255 any
The 2nd 878.router has the below configuration:
ip source-route
ip dhcp excluded-address 10.0.1.1 10.0.1.99
ip dhcp excluded-address 10.0.1.201 10.0.1.255
ip dhcp pool IMG-DATA
   network 10.0.1.0 255.255.255.0
   default-router 10.0.1.1
   dns-server XXX
interface ATM0
 no ip address
 pvc 8/48
 ip nat outside
 tunnel protection ipsec profile EXT_IPSEC
interface Vlan1
 ip nat inside
interface Dialer0
 ip nat outside
 encapsulation ppp
 dialer pool 1
ip local pool VPN_POOL 10.0.4.10 10.0.4.254
no ip http server
ip nat pool SRV-POOL 10.0.1.249 10.0.1.249 netmask 255.255.255.0 type rotary
ip nat inside source static tcp 10.0.1.249 443 interface Dialer0 443
ip nat inside source static tcp 10.0.1.249 21 interface Dialer0 12021
ip nat inside source static tcp 10.0.1.249 80 interface Dialer0 80
ip nat inside destination list 100 pool SRV-POOL
ip access-list extended SRV
 permit tcp host 10.0.1.249 any range 49152 65535
route-map SRV-RM permit 10
 match ip address SRV
I need your help in the below questions?
1. What dns-server should I set in both routers? Should it be for example; 192.168.1.1 , 10.0.1.1, or I should assign the IP address of Dialer0 from the ISP?
2. I have noticed that there is a huge slowness in the internet speed, why?
3. Do you think it's better to move the configuration of CISCO Router 878 to a new 887VA router as I have extra 887 router in the stock?
4. Any comments or entries I should modify on both configuration if I want to stick with 887VA and 878 routers?
Thanks in advance!
changes to your configs are in bold. Is your VPN dialup working correctly ?
The 878 is EoL (End of Life), so if you have a new 887VA, by all means install it.
887VA
dns-server 8.8.8.8 8.8.4.4
interface ATM0
no ip address
hold-queue 224 in
pvc 8/48
protocol ppp dialer
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
ip nat inside
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1460
ip nat outside
ip tcp adjust-mss 1420
encapsulation ppp
dialer pool 1
no cdp enable
ip http server
ip dns server
878 Router
ip source-route
interface ATM0
no ip address
pvc 8/48
ip nat outside
interface Vlan1
ip nat inside
interface Dialer0
ip nat outside
ip mtu 1460
encapsulation ppp
dialer pool 1
no ip http server
and priority queuing for egress traffic
The VPN is working fine.
WHat do you mean by "and priority queuing for egress traffic"?
Currently, I have two CISCO routers 887VA from series 800. I have configured both of them as shown below (Blue_Router , Green_Router).
- Green_Router is working fine since a week.
- Blue_Router worked fine yesterday, but I have just noticed that the whole configuration got erased and I can't reach it via Telnet. Note that I have saved the configuration yesterday.
Please check the below configuration for both Blue_Router and Green_Router, note that the issue is only on Blue
Blue_Router#show run
Current configuration : 3820 bytes
version 15.5
hostname Blue_Router
boot-start-marker
boot-end-marker
aaa new-model
ethernet lmi ce
ip dhcp pool IM-DATA
 dns-server 10.0.1.1
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
 no ip address
 pvc 8/48
interface Ethernet0
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip nat outside
 tunnel protection ipsec profile DFS-EXT_IPSEC
interface Vlan1
 ip nat inside
interface Dialer0
 ip nat outside
 encapsulation ppp
 dialer pool 1
no ip http server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line vty 0 4
 privilege level 15
scheduler allocate 20000 1000
end
Blue_Router#
Green_Router#show run
Current configuration : 5759 bytes
version 15.5
hostname Green_Router
boot-start-marker
boot-end-marker
aaa new-model
aaa authorization network VPN_GROUP local
ethernet lmi ce
 dns-server 8.8.8.8
no ip domain lookup
ip domain name yourdomain.com
ip cef
no ipv6 cef
archive
 log config
  hidekeys
controller VDSL 0
interface ATM0
 no ip address
 hold-queue 224 in
 pvc 8/48
  protocol ppp dialer
interface Ethernet0
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip nat inside
 tunnel protection ipsec profile VPN_IPSEC_PROFILE
interface Vlan1
 ip nat inside
interface Dialer0
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 no cdp enable
ip http server
ip dns server
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 access-class 23 in
 exec-timeout 0 0
 privilege level 15
end
Green_Router#
both configurations look correct. Are you running into a specific issue ?
Hello Georg,
Yes, I have an issue with the Blue_Router
The configuration keeps lost after a few hours or a day, and I cann't ping it or reach it via telnet.
The only way to reach it is to connect it via console and do the configuration again, also this won't help as the same issue will happen again randomly.
Could it be that I have to add "ip tcp adjust-mss 1452", "ip mtu 1492", "ip http timeout-policy idle 60 life 86400 requests 10000" entries?
Please advise
there could be a problem with the compact flash. I would do the following:
1. wr erase --> this will erase the content of the NVRAM
2. erase flash: --> this will erase all files on the flash card
3. format flash: --> this will reformat the flash card
Then enter the configuration again and check if it stays on there...
Hello Georg,
Should I enter the three commands in order, then write the configuration again?
Also, what about the below entries, should I add them to my configuration file or not?
ip mtu 1492
Awad
yes, enter the commands in order.
The configuration lines you are asking about are ok, you can enter them into your new configuration...
Hello Georg,
I will do as you asked  and will keep my eye on it to see if the issue will occur again or not.
Note that both routers are new and I've just purchased them week ago.
Thanks.,
I have almost used the same configuration as I used before, but the configuration keeps lost and I can't reach it via telnet. The only way to reach it is through console and re-write the configuration again, which will also get lost after a day.
Current configuration : 4042 bytes
version 15.5
boot-start-marker
boot-end-marker
aaa new-model
ethernet lmi ce
ip dhcp pool MG-DATA
 dns-server X.X.X.X 8.8.8.8
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ2130E16N
username xxxx privilege 15 password 0 xxxx
controller VDSL 0
interface ATM0
 no ip address
 hold-queue 224 in
 pvc 8/48
  protocol ppp dialer
interface Ethernet0
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip nat outside
interface Vlan1
 ip nat inside
interface Dialer0
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp pap sent-username xxx password 0 xxx
 no cdp enable
no ip http server
ip route 0.0.0.0 0.0.0.0 Dialer0
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 privilege level 15
end
Blue_Router#
Please advise
Same issue still exist on the Blue_Router.
I have also used the same configuration on other router, and the issue keeps happening.
After the issue occured,I have noticed that ATM0 interface went down, and Dialer0 interface disappeared from "Show ip int br".
Please advise
are you losing the entire confguration, or just the dialer interface ?
Your dialer interface is tied to the ATM physical interface, so it makes sense that if the ATM goes down, the dialer interface disappears from the 'sh ip int brief'...
