Correct/Incorrect configuration of CISCO Router 877
Hello all,
I do not have much experience with configuring CISCO Routers, but I had to try configuring it.
Below is the output from Show Run command, please check below and let me know if anything is missing or if I need to adjust things in a correct way.
blue#show run
Building configuration...
Current configuration : 2341 bytes
version 12.4
no service pad
hostname blue
boot-start-marker
boot-end-marker
logging message-counter syslog
aaa new-model
aaa authentication login VPN_XAUTH local
aaa authentication login LOGIN local
aaa authentication enable default enable
aaa authorization console
aaa authorization exec LOGIN local if-authenticated
aaa authorization commands 15 LOGIN local if-authenticated
aaa authorization network VPN_GAUTH local
aaa session-id common
dot11 syslog
ip source-route
ip cef
username XXX privilege 15 password 0 XXX
archive
 log config
  hidekeys
interface ATM0
 no ip address
 no atm ilmi-keepalive
 pvc 8/48
  pppoe-client dial-pool-number 1
 dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template1 type tunnel
 ip unnumbered Dialer0
 ip nat outside
 ip virtual-reassembly
 tunnel mode ipsec ipv4
interface Vlan1
 ip address 10.0.1.1 255.255.255.0
 ip nat inside
interface Dialer0
 no ip address
interface Dialer1
 ip address negotiated
 ip mtu 1380
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp pap sent-username XXX password 0 XXX
ip local pool VPN_IP_POOL 10.0.4.10 10.0.4.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 101 interface Dialer1 overload
ip access-list extended VPN_ACL
 permit ip 10.0.1.0 0.0.0.255 10.0.4.0 0.0.0.255
access-list 23 permit 10.0.4.0 0.0.0.255
access-list 23 permit 10.0.1.0 0.0.0.255
access-list 100 permit tcp any any range 49152 65535
access-list 101 deny   ip 10.0.1.0 0.0.0.255 10.0.4.0 0.0.0.255
access-list 101 permit ip 10.0.1.0 0.0.0.255 any
access-list 101 permit ip 10.0.4.0 0.0.0.255 any
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 access-class 23 in
 exec-timeout 0 0
 privilege level 15
 login authentication LOGIN
 transport input telnet ssh
scheduler max-task-time 5000
end
blue#
17 Replies 17
I lose the entire configuration.
sounds like a memory issue...
Have you tried what I suggested in a previous post ?
1. wr erase --> this will erase the content of the NVRAM
2. erase flash: --> this will erase all files on the flash card
3. format flash: --> this will reformat the flash card
Yes, I have tried the below:
Then wrote the configuration again, but same behaviour as after a day, everything disappear.
I have also tried the same configuration on a new functioning router with the same model, and the same issue occured again.
