Correct way to configure Rendezvous point redundancy when using Auto-RP
carl_townshend
Hi there
Can anyone tell me when we use Auto RP, do you need to configure Anycast RP and use the same loopback IP on 2 different routers with MSDP between them? or can you use different IP addresses and just let the mapping agents pick the best one and if one fails they will advertise the other one?
How should it be done when using Auto RP, what would the config look like?
cheers
Mark Elsen
 - Check the document below which also discusses a few anycast scenarios and or options :
              https://www.cisco.com/c/en/us/td/docs/ios/solutions_docs/ip_multicast/White_papers/rps.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
