CPU utilization 80% to 90% due to TTY background process on cisco 2960
Nirqa suport
I have a 2960X switch that has high CPU usage, I have checked the CPU processes and I see that the TTY Background process is using.
I provide information from show version, show cpu history and show process cpu sorted.
PERVENTSW01OUT#show processes cpu history
887888888788778887777888878888887889977877888888777778887777
331115522500990051199003352211226115599511000033288992241199
100 **
90 ** * ** *
80 ** ************** ********************* ****** *******
70 **********************************************************
60 **********************************************************
50 **********************************************************
40 **********************************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
988888888888888888888888888888888888888888888888888888888888
545555755565455655465555655555546455455445456555556555556546
100 *
90 * ********** ***** ************ * ** ** * ***************
80 ##########################################################
70 ##########################################################
60 ##########################################################
50 ##########################################################
40 ##########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
888888888888889888888888988888888888888888888888888998888888888888888888
979876677677781676877777177777769997679777777668677008779778797797679685
100
90 **********************************************************************
80 ######################################################################
70 ######################################################################
60 ######################################################################
50 ######################################################################
40 ######################################################################
30 ######################################################################
20 ######################################################################
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
PERVENTSW01OUT#show version
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 12-Jul-17 13:06 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(3r)E1, RELEASE SOFTWARE (fc1)
PERVENTSW01OUT uptime is 2 years, 28 weeks, 2 hours, 30 minutes
System restarted at 14:04:12 PERU Wed Nov 23 2022
System image file is "flash:/c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-48FPS-L (APM86XXX) processor (revision V0) with 524288K bytes of memory.
Processor board ID FJC2238W0JH
Last reset from power-on
8 Virtual Ethernet interfaces
1 FastEthernet interface
104 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:B1:E3:85:72:80
Motherboard assembly number : 73-16691-07
Power supply part number : 341-0527-03
Motherboard serial number : FJZ22370LEA
Power supply serial number : LIT2230399C
Model revision number : V0
Motherboard revision number : A0
Model number : WS-C2960X-48FPS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FJZ223706P2
System serial number : FJC2238W0JH
Top Assembly Part Number : 68-100469-04
Top Assembly Revision Number : B0
Version ID : V07
CLEI Code Number : CMMZ100ARA
Daughterboard revision number : B0
Hardware Board Revision Number : 0x19
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960X-48FPS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
2 52 WS-C2960X-48FPS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
Switch 02
Switch Uptime : 2 years, 28 weeks, 2 hours, 31 minutes
Base ethernet MAC Address : 70:0B:4F:D9:A3:00
Motherboard serial number : FJZ22370LPH
Power supply serial number : LIT2230337A
Daughterboard serial number : FJZ223706ST
System serial number : FJC2238W0PG
Top assembly part number : 68-100469-04
Top assembly revision number : B0
Version ID : V07
Configuration register is 0xF
PERVENTSW01OUT#sh process cpu sorted
CPU utilization for five seconds: 80%/0%; one minute: 79%; five minutes: 79%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  51  2454984320    77687527      31601 55.42% 54.86% 54.67%   0 TTY Background
161  3162245930  1949397712       1622  8.00%  8.08%  8.16%   0 Hulc LED Process
392     2229806     9383620        237  0.63%  0.19%  0.18%   0 SNMP ENGINE
390     3141759    18133355        173  0.47%  0.16%  0.15%   0 IP SNMP
206    20449109   144962376        141  0.31%  0.65%  0.59%   0 IP Input
172   294243411    15958233      18438  0.26%  0.31%  0.31%   0 HQM Stack Proces
173   100295807    63832357       1571  0.15%  0.10%  0.10%   0 HRPC qos request
131   202365757    78525209       2577  0.10%  0.12%  0.11%   0 hpm counter proc
  95      575520    39784541         14  0.10%  0.01%  0.00%   0 hrpc -> response
  48    11144044    92776820        120  0.10%  0.03%  0.02%   0 Net Background
391      539419     9067190         59  0.05%  0.02%  0.00%   0 PDU DISPATCHER
167        1117        1391        803  0.05%  0.02%  0.04%   1 SSH Process
132    26418636   131525914        200  0.05%  0.03%  0.01%   0 HRPC pm-counters
192    19757468    38904877        507  0.05%  0.04%  0.05%   0 CDP Protocol
  59     1442449    16095868         89  0.05%  0.02%  0.00%   0 Compute load avg
219    50264857   136131751        369  0.05%  0.05%  0.05%   0 Spanning Tree
  16      215482    81108123          2  0.00%  0.00%  0.00%   0 ARP Background
  15    30089162    92816071        324  0.00%  0.00%  0.00%   0 ARP Input
I have searched for information and apparently there is a bug, but it does not meet the requirements of the bug, let me know if anyone has any ideas on how to address the problem and solve the high CPU usage.
My config of line is:
no vstack
line con 0
line vty 5 15
5 Replies 5
GIZOOOOOO8452
Do you consider the sw config very large or it just switching configuration
Do you take any backup of configuration during this time or not
You may need to use even manager to show process CPU during the issue
Leo Laohoo
Post the complete output to the command "who".
There are
1- ssh/telent
2- some session and monitor protocol
Use tty
Tty  by it nature is heavy on cpu' run many tty make cpu utilize high
So start by do
Show line
Show user
And if you can
Clear line vty <<- this will kill all vty still open' be carefull before do that
Share config of vty
MHM
M02@rt37
Hello @Nirqa suport
If you could reboot your platforms and programm an upgrade also to a suggested IOS Firmware: 15.2.7E8
Best regards
shambhu.kumar
There is 8% of CPU consuming by Hulc LED Process. This behavior described in CSCtg86211 and is expected for catalyst 2960x switch models.
15.2(2)E7 is old enough,  detected with multiple vulnerabilities (CVE-2025-20154, CVE-2025-20181).
