Crafted ICMP Messages vulnerability on a 7200 router
benlambrey
I have question regarding the advisory "Crafted ICMP Messages Can Cause Denial of Service"
http://www.cisco.com/warp/public/707/cisco-sa-20050412-icmp.shtml
We're running a Cisco 7200 router "IOS (tm) 7200 Software (C7200-P-M), Version 12.1(19), RELEASE SOFTWARE (fc1)"
It's unclear to me if our router is vulnerable to the above bug
or not.
Who can clarify this to me?
Thanks.
Ben.
thisisshanky
Level 11
Level 11
Ben,
All Cisco IOS versions are vulnerable to this attack. It depends on what protocols/apps you are running on the router. For example if the router initiates a TCP/IP connection to another device, then your router will be vulnerable to this attack. If you use IPSEC or DMVPN or GRE tunnels, you are vulnerable. Paste a show run with important info masked, and we can see from there if your router is affected or not.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for your answer, but 'show run' is not a valid command on a 7200.
What information should I provide?
Ben.
