Creating Whitelist with MQC
petrutz_21
There is one client
192.168.1.10
and i want that this cklient to have web acces just on www.xxx.org and www.xxx.com and the others users have a web full access.
I have made this:
class-map match-any AUTHORIZED_URLS
match protocol http url "*.xxx.org"
match protocol http url " *.xxx.com"
ip access-list extended RESTRICTED_USERS
  permit tcp host 192.168.1.10 any eq www
class-map match-all USER_URLS
match access-group name RESTRICTED_USERS
match  not class AUTHORIZED_URL
policy-map URL_POLICY
class USER_URLS
drop
interface Vlan1
service-policy input URL_POLICY
The problem is that the client
192.168.1.10
doesn't have any web acces.
Where is the problem ?
7 Replies 7
Velimir Filipov
Inside the class AUTHORIZED_URLS try altering the syntax. I guess its using regex.
match protocol http url ".*\.xxx.org"
or
match protocol http url ".*\.xxx.org.*"
or
match protocol http url ".*xxx.org"
or just
match protocol http url "xxx.org"
and maybe try matching host not url, as actually host stands for the portion of the URL that responds to the actual hostname of the website, and URI stands for the actual resource your looking on the particular website.
I have tried all :
or
or
or just
and
match protocol http host ".*\.xxx.org"
or
match protocol http host ".*\.xxx.org.*"
or
match protocol http host ".*xxx.org"
or just
match protocol http host "xxx.org"
but still not working.
I don't have any web acces on my host 192.168.1.10.
Ok let me make some tests and I will get back to you in 2 hours or so.
Ok, sorry for the delay.
It seems its not regex. It's just the way you did it, only that as I supposed you need to match host not url.
So the right syntax would be:
match protocol http host "*.xxx.org"
match protocol http host "*.xxx.com"
also its probably best to drop the . also cus it could be open the website without www. infront, so "*xxx.org" and "*xxx.com" is the best thing you could go with.
Best regards.
match protocol http host "facebook.com"
match  not class AUTHORIZED_URLS
class USER_URLS
drop
permit tcp host 192.168.1.56 any eq www
interface Vlan1
Still don't have any web access from 192.168.1.56. I'm tring to acces www.facebook.com and it doesen't work.
put * infront of facebook.com
Nop !! Not working !!
