cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
CSR in AWS - Allow internet traffic to an instance
mthomaz
I've created 2x Cisco CSR 1000V in AWS, and have launched an instance in the private subnet (behind the CSR).
Now, I want that instance to have internet access.
I can ping/ssh the instance from the CSR, but I cannot connect to the instance via SSH using its public IP address. I assume I need to tell the CSR that I want to allow traffic to that instance.
How to do that?
ip-10-0-0-171#show ip int b
GigabitEthernet1 10.0.0.171 YES DHCP up up #outside
GigabitEthernet2 10.0.1.147 YES DHCP up up #internal IP address
The inside network is: 10.0.1.0/24 - It should allow outgoing traffic from 10.0.1.0/24 to the internet.
Also, if I need to create a NAT entry that redirects port 2222 from the outside interface to 10.0.1.154, how do I do that?
Thanks!
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
mthomaz
I managed to get this working with the following:
  • ap-southeast-2 private network: 10.1.2.0
  • ap-northeast-1 private network: 10.5.2.0
# AWS Sydney (ap-southeast-2):
crypto ikev2 profile default
match identity remote fqdn domain cisco.com
identity local fqdn CSR1.cisco.com
authentication remote pre-share key cisco123
authentication local pre-share key cisco123
exit
interface tunnel1
ip address 172.16.0.1 255.255.255.252
tunnel source GigabitEthernet 1
tunnel destination 52.x.x.206
tunnel protection ipsec profile default
crypto ikev2 dpd 10 2 on-demand
show crypto ipsec profile default
router eigrp 1
network 172.16.0.0 0.0.0.255
network 10.1.2.0 0.0.0.255
ip route 10.5.2.0 255.255.255.0 tunnel1
interface GigabitEthernet1
ip nat outside
interface GigabitEthernet2
ip nat inside
ip access-list extended NAT
permit ip 10.1.2.0 0.0.0.255 any
ip nat inside source list NAT interface GigabitEthernet1 overload
no ip nat inside source list GS_NAT_ACL interface GigabitEthernet1 vrf GS overload
wr
# AWS Tokyo (ap-northeast-1):
identity local fqdn CSR2.cisco.com
exit
interface tunnel1
ip address 172.16.0.2 255.255.255.252
tunnel destination 3.x.x.27
router eigrp 1
network 10.5.2.0 0.0.0.255
ip route 10.1.2.0 255.255.255.0 tunnel1
ip nat outside
ip nat inside
permit ip 10.5.2.0 0.0.0.255 any
wr
Ver la solución en mensaje original publicado
3 RESPUESTAS 3
post the configs of the CSRs. As far as I can see, you need a split tunnel setup with NAT (SVTI or DMVPN, since you cannot use NAT and crypto maps on the same interface with AWS)...
Hope this helps. Let me know if you need anything else.
It is worth reminding that the Linux VM is connected to a Private Subnet, which points to the GigabitEthernet2 as its default gw.
I can reach the VM from the CSR, but I cannot connect to the VM using its elastic IP address, or don't have internet from the instance.
GigabitEthernet1 - The outside interface
GigabitEthernet2 - The internal interface, which connects to the VMs
Tunnel0 - is connected to the other CSR (CSR 2 for HA). I don't think I need to give you the CSR2's configuration as it is pretty much the same.
CSR1#show running-config
Building configuration...
Current configuration : 4761 bytes
! Last configuration change at 03:54:57 UTC Mon May 27 2019
version 16.10
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform console virtual
hostname CSR1
boot-start-marker
boot-end-marker
vrf definition GS
 rd 100:100
 address-family ipv4
 exit-address-family
logging persistent size 1000000 filesize 8192 immediate
no aaa new-model
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-2886621095
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2886621095
 revocation-check none
 rsakeypair TP-self-signed-2886621095
crypto pki certificate chain TP-self-signed-2886621095
 certificate self-signed 01
  30820330
[ ... hidden for security reasons... ]
 BAEBE008
        quit
license udi pid CSR1000V sn 9Q [ ... hidden for security reasons... ] NO
no license smart enable
diagnostic bootup level minimal
username ec2-user privilege 15 secret 9 $9$VLn04MyBv [ ... hidden for security reasons... ] 8o/nr2A4Cgc
username 54.54.54.54
redundancy
 cloud provider aws 1
  bfd peer 172.17.1.2
  route-table rtb-0f73fdbdcbccdfb9b
  cidr ip 0.0.0.0/0
  eni eni-0560a232631575425
  region ap-southeast-2
interface Tunnel0
 ip address 172.17.1.1 255.255.255.252
 ip ospf 1 area 0
 bfd interval 500 min_rx 500 multiplier 3
 tunnel source GigabitEthernet1
 tunnel destination 3.3.3.3
interface VirtualPortGroup0
 vrf forwarding GS
 ip address 192.168.35.101 255.255.255.0
 ip nat inside
 no mop enabled
 no mop sysid
 ip address dhcp
 ip nat outside
 negotiation auto
 no mop enabled
 no mop sysid
 ip address dhcp
 negotiation auto
 no mop enabled
 no mop sysid
router ospf 1
 bfd all-interfaces
iox
ip forward-protocol nd
ip tcp window-size 8192
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet1 10.0.0.1
ip route vrf GS 0.0.0.0 0.0.0.0 GigabitEthernet1 10.0.0.1 global
ip ssh rsa keypair-name ssh-key
ip ssh version 2
ip ssh pubkey-chain
  username ec2-user
   key-hash ssh-rsa 8F [ ... hidden for security reasons... ] 10 ec2-user
ip scp server enable
ip access-list standard GS_NAT_ACL
 permit 192.168.35.0 0.0.0.255
control-plane
line con 0
 stopbits 1
line vty 0 4
 login local
 transport input ssh
app-hosting appid guestshell
 app-vnic gateway1 virtualportgroup 0 guest-interface 0
  guest-ipaddress 192.168.35.102 netmask 255.255.255.0
 app-default-gateway 192.168.35.101 guest-interface 0
 name-server0 8.8.8.8
end
mthomaz
exit
interface tunnel1
router eigrp 1
ip nat outside
ip nat inside
wr
exit
interface tunnel1
router eigrp 1
ip nat outside
ip nat inside
wr
