CSS 11503: Register a node as online in CSS11503 programatically
purepure01
we use a CSS11503 content switch and we would like to know if it is possible to programatically register a node as available in the 11503.
The startup sequence for a cluster node would be:
1. perform sanity check
2. indicated for the CSS11503 that the node is available
Today we use the polling facility in 11503 but we feel that it would be nicer if we can control the availability of a node from the node itself.
thomas.chen
Level 6
Level 6
Set the alternative group policies for which you want to configure support for Citrix to enable WebVPN tunneling. By default, users inherit the Functions settings from their respective assigned group policies.Refer URL
http://www.cisco.com/en/US/products/ps6121/products_configuration_guide_chapter09186a00806a95a4.html#wp1044933
