CSS - version 7.50 - Loadbalancing - Microsoft OWA
lisasmith
I have successfully used the CSS to load-balance an application in our network for some time. I have just added to the configuration to allow load-balance of new Microsoft Exchange Servers. It appears that the load-balancing works for Microsoft Outlook users but "not" for Microsoft OWA users. It appears that Microsoft OWA users cannot get to the site when the rules are active. We cannot find in Cisco docs what we are missing. I have included my configuration below. Any help is really appreciated. Thanks. Lisa
CSS11503# sho version
Version: sg0750004 (07.50.0.04)
Flash (Locked): 07.50.0.04
Flash (Operational): 07.50.0.04
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
CSS11503# sho run
!Generated on 04/15/2009 09:43:16
!Active version: sg0750004
configure
!*************************** GLOBAL ***************************
username admin des-password mgjftayesavg4euabg1e3gagef5fkgvh superuser
snmp community 3duc8ti0n read-write
snmp auth-traps
ip route 0.0.0.0 0.0.0.0 10.1.0.1 1
!************************* INTERFACE *************************
interface 1/1
bridge vlan 20
!************************** CIRCUIT **************************
circuit VLAN1
ip address 10.1.0.5 255.255.240.0
circuit VLAN20
ip address 10.254.0.2 255.255.255.248
!************************** SERVICE **************************
service ClientAccess61
ip address 10.1.0.61
service ClientAccess66
ip address 10.1.0.66
service eSISProd1
ip address 10.1.0.6
active
service eSISProd2
ip address 10.1.0.7
active
service eSISProd3
ip address 10.1.0.15
active
!*************************** OWNER ***************************
owner ExchangeClientAccessServers
content L3_Rule
add service ClientAccess61
add service ClientAccess66
balance aca
protocol tcp
advanced-balance sticky-srcip
vip address 10.1.0.72
active
content SR
protocol tcp
port 443
redirect "https://exchange.access-k12.org"
active
owner L3_Owner
content L3_Rule
add service eSISProd1
add service eSISProd2
balance aca
vip address 10.1.0.8
protocol tcp
add service eSISProd3
active
content SR
protocol tcp
port 80
redirect "http://esis.access-k12.org:7777/forms/frmservlet?config=esis"
active
!*************************** GROUP ***************************
group CASExchange
add destination service ClientAccess61
add destination service ClientAccess66
active
group serer
add destination service eSISProd1
add destination service eSISProd2
add destination service eSISProd3
active
CSS11503#
aghaznavi
Level 5
Level 5
See if you have inserted the text string. The primary purpose of text string insertion in the HTTP header to a back-end server is to support Microsoft Outlook Web Access (OWA) applications.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v7.50/configuration/ssl/guide/terminat.html
