12-29-2008 06:25 AM - edited 03-04-2019 03:15 AM
I am working on a project and need to perform some tests on equipment. We do not want to connect this to our live network so I have 2 routers with csu's for testing. I am using Frame relay and I'm pretty sure I have my speeds right and know my encapsulation is right. I have tried a straight through cable and a cross-over cable and can't see to get them to sync up with each other. Do I need to set my cable to a differnet type of pin-out to make this work? Any ideas would be appreciated.
12-29-2008 06:40 AM
Try a T1 cross-over cable.
http://www.ldfacts.com/faq_files/How-to-Make-a-T1-Crossover-cable.htm
Hope that helps.
12-29-2008 06:42 AM
Thank you! I think that is exactly what I'm looking for.
