CUBE Calls disconnect cause 102
louisKl1
Currently working on a CUBE and Teams configuration. The status of calls is the following :
Endpoint  ---> CUBE ---> Teams user [Working]
Endpoint (+33296086772)  <--- CUBE <--- Teams user (+33296086769) [Not working]
When the teams user calls the endpoitn, INVITE (and other sip) messages go through and session establishes however after a few seconds, I get a "Disconnect: Initiated at: 0x1703B37, Originated at:0x1E000FD, Cause Code = 102".
You will find attached the current configuration of the CUBE and the log of the not working call scenario.
Apr 25 11:58:28: //13731/03B4A481B65A/SIP/Error/sipSPIFlushDeferredQueue:
Invalid deferredQueue
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+33296086772@hq692gw.msvisit6.one.equant.net:5064;user=phone;transport=tls SIP/2.0
FROM: "HQ692gw-teams1"<sip:+33296086769@sip.pstnhub.microsoft.com:5061;user=phone>;tag=ac87d0e19fde43efb68fe6ed361312e0
TO: <sip:+33296086772@hq692gw.msvisit6.one.equant.net:5064;user=phone>
CSEQ: 1 INVITE
CALL-ID: 26bc3a05cc825a2d9e8752e0085d3280
MAX-FORWARDS: 70
VIA: SIP/2.0/TLS 52.114.76.76:5061;branch=z9hG4bK482d4de3
RECORD-ROUTE: <sip:sip-du-a-eu.pstnhub.microsoft.com:5061;transport=tls;lr>
CONTACT: <sip:api-du-c-euwe.pstnhub.microsoft.com:443;x-i=0702d4ae-cc70-47ac-a163-f1dcd9d4cb72;x-c=26bc3a05cc825a2d9e8752e0085d3280/d/8/ca53ba2a53064ff28b5601705ff77ab1>
CONTENT-LENGTH: 1100
MIN-SE: 300
SUPPORTED: histinfo,timer
USER-AGENT: Microsoft.PSTNHub.SIPProxy v.2022.4.18.2 i.EUNO.11
CONTENT-TYPE: application/sdp
ALLOW: INVITE,ACK,OPTIONS,CANCEL,BYE,NOTIFY
P-ASSERTED-IDENTITY: <tel:+33296086769>,<sip:hq692gw-teams1@msvisit6.one.equant.net>
PRIVACY: id
SESSION-EXPIRES: 3600
X-MS-UserLocation: external
X-MS-MediaPath: hq692gw.msvisit6.one.equant.net
v=0
o=- 11924 0 IN IP4 127.0.0.1
s=session
c=IN IP4 52.113.227.8
b=CT:10000000
t=0 0
m=audio 51708 RTP/SAVP 104 9 103 111 18 0 8 97 101 13 118
a=rtcp:51709
a=ice-ufrag:quUM
a=ice-pwd:Ex6lXZ++Mqtjr0uu7pxpnqF2
a=rtcp-mux
a=candidate:1 1 UDP 2130706431 52.113.227.8 51708 typ srflx raddr 10.0.140.239 rport 51708
a=candidate:1 2 UDP 2130705918 52.113.227.8 51709 typ srflx raddr 10.0.140.239 rport 51709
a=candidate:2 1 tcp-act 2121006078 52.113.227.8 49152 typ srflx raddr 10.0.140.239 rport 49152
a=candidate:2 2 tcp-act 2121006078 52.113.227.8 49152 typ srflx raddr 10.0.140.239 rport 49152
a=label:main-audio
a=mid:1
a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
a=sendrecv
a=rtpmap:104 SILK/16000
a=rtpmap:9 G722/8000
a=rtpmap:103 SILK/8000
a=rtpmap:111 SIREN/16000
a=fmtp:111 bitrate=16000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:97 RED/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=rtpmap:118 CN/16000
a=ptime:20
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
Apr 25 11:58:30: //-1/181BB940B660/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
MF: Dial-peer is absent..
Apr 25 11:58:30: //-1/181BB940B660/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
MF:video profile Dial-peer is absent..
Apr 25 11:58:30: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Apr 25 11:58:30: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:7F8CE8B64EE0
Apr 25 11:58:30: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:3600, SE Refresher:none, Min-SE Value:1800, flags:2011
SIP: (13737) ice-lite attribute, level 65535 instance 1 not found.
SIP: (13737) ice-mismatch attribute, level 65535 instance 1 not found.
SIP: (13737) ice-options attribute, level 65535 instance 1 not found.
SIP: (13737) remote-candidate attribute, level 1 instance 1 not found.
SIP: (13737) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: (13737) setup attribute, level 1 instance 1 not found.
SIP: (13737) connection attribute, level 1 instance 1 not found.
SIP: (13737) a=framerate attribute, level 1 instance 1 not found.
Apr 25 11:58:30: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Apr 25 11:58:30: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:7F8CE8B66C88
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Apr 25 11:58:30: //13737/181BB940B660/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TLS 52.114.76.76:5061;branch=z9hG4bK482d4de3
From: "HQ692gw-teams1"<sip:+33296086769@sip.pstnhub.microsoft.com:5061;user=phone>;tag=ac87d0e19fde43efb68fe6ed361312e0
To: <sip:+33296086772@hq692gw.msvisit6.one.equant.net:5064;user=phone>
Date: Mon, 25 Apr 2022 09:58:30 GMT
Call-ID: 26bc3a05cc825a2d9e8752e0085d3280
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-17.3.4a
Session-ID: 00000000000000000000000000000000;remote=43ac6cb2eb565b6eb9d0e33a6b06746e
Content-Length: 0
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
Unexpected VoIPCodec Type :No Codec
SIP: (13738) Group (a= group line) attribute, level 65535 instance 1 not found.
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Apr 25 11:58:30: //13738/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Apr 25 11:58:30: //13738/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:7F8CE8B66190
Apr 25 11:58:30: //13738/181BB940B660/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:3600, SE Refresher:none, Min-SE Value:1800, flags:2011
Apr 25 11:58:30: //13738/181BB940B660/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+33296086772@6.6.51.1:5062 SIP/2.0
Via: SIP/2.0/TCP 6.6.92.1:5060;branch=z9hG4bK11FF1ECF
From: "HQ692gw-teams1" <sip:+33296086769@6.6.92.1>;tag=EF8D190-20CC
To: <sip:+33296086772@6.6.51.1>
Call-ID: 181D66FA-C3B511EC-B6668EA1-83F540C@6.6.92.1
Supported: timer,resource-priority,replaces,sdp-anat,X-cisco-srtp-fallback
Min-SE: 1800
Cisco-Guid: 0404470080-3283423724-3059781281-0138368012
User-Agent: Cisco-SIPGateway/IOS-17.3.4a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1650880710
Contact: <sip:+33296086769@6.6.92.1:5060;transport=tcp>
Expires: 1800
Max-Forwards: 69
Session-ID: 43ac6cb2eb565b6eb9d0e33a6b06746e;remote=00000000000000000000000000000000
Session-Expires: 3600
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 386
v=0
o=CiscoSystemsSIP-GW-UserAgent 8044 8537 IN IP4 6.6.92.1
s=SIP Call
c=IN IP4 6.6.92.1
t=0 0
m=audio 8170 RTP/SAVP 18 8 101
c=IN IP4 6.6.92.1
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=label:main-audio
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 6.6.92.1:5060;branch=z9hG4bK11FF1ECF;rport=40673
CSeq: 101 INVITE
User-Agent: ACTa v3.5.1
Content-Length: 0
Received:
SIP/2.0 180 Ringing
To: <sip:+33296086772@6.6.51.1>;tag=1403425168
Contact: <sip:0296086772@6.6.51.1:5062>
Accept: application/sdp,application/isup,application/xml,multipart/mixed,application/vnd.orange.indata
Allow: INVITE,ACK,BYE,CANCEL,INFO,UPDATE,NOTIFY,OPTIONS
CSeq: 101 INVITE
Content-Length: 210
v=0
o=ACTa_v3.5.1 1649653695575 1648840840904 IN IP4 6.6.51.1
s=-
c=IN IP4 6.6.51.1
t=0 0
m=audio 57444 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
SIP: Attribute mid, level 1 instance 1 not found.
SIP: setup attribute, level 1 instance 1 not found.
SIP: connection attribute, level 1 instance 1 not found.
SIP: Attribute label, level 1 instance 1 not found.
SIP: a=framerate attribute, level 1 instance 1 not found.
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for +33296086769
No entry found in reg Number Table for +33296086772
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
ReqLine IP addr does not match with host IP addr
Apr 25 11:58:30: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Apr 25 11:58:30: //13737/181BB940B660/SIP/Error/sipSPIAddSrtpSession:
SRTP session creation failed
Apr 25 11:58:30: //13738/181BB940B660/SIP/Error/sipSPIGetNewLocalMediaDirection:
Unknown media direction (0) from remote end
Apr 25 11:58:30: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:183, container:7F8CE8B66468
Sent:
SIP/2.0 183 Session Progress
To: <sip:+33296086772@hq692gw.msvisit6.one.equant.net:5064;user=phone>;tag=EF8D1C3-16AD
CSeq: 1 INVITE
Contact: <sip:0296086772@6.6.92.129:5064;transport=tls>
Record-Route: <sip:sip-du-a-eu.pstnhub.microsoft.com:5061;transport=tls;lr>
Supported: sdp-anat
Session-ID: 7be33c3fdd115e5bb7effee29994ac66;remote=43ac6cb2eb565b6eb9d0e33a6b06746e
Content-Length: 571
v=0
o=CiscoSystemsSIP-GW-UserAgent 3625 3120 IN IP4 6.6.92.129
s=SIP Call
c=IN IP4 6.6.92.129
t=0 0
a=ice-lite
m=audio 8168 RTP/SAVP 8 13 101
c=IN IP4 6.6.92.129
a=mid:1
a=candidate:1 1 UDP 2130706431 6.6.92.129 8168 typ host
a=candidate:1 2 UDP 2130706430 6.6.92.129 8169 typ host
a=rtcp:8169 IN IP4 6.6.92.129
a=ice-ufrag:1rg1
a=ice-pwd:J3KTBXC931f8kseGdqN8q4
a=rtpmap:13 CN/8000
a=fmtp:101 0-16
a=ptime:20
Apr 25 11:58:34: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Apr 25 11:58:35: //-1/xxxxxxxxxxxx/SIP/Error/sip_tls_tcp_read_socket:
Connid 5479 closed by remote peer
Apr 25 11:58:35.456: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=54528, connId=5479
Apr 25 11:58:35: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_process_tls_tcp_queue_event:
Invalid Conn Entry=5479/fd=-1
Apr 25 11:58:37: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:6.6.92.1:5060 SIP/2.0
Via: SIP/2.0/UDP 172.22.245.209:5060;branch=z9hG4bKfe88g820boerajhb1h60
Call-ID: f1afabef2c2e89d6c987bdc0ed46677f050000gtj3300@172.22.245.209
To: sip:ping@6.6.92.1
From: <sip:ping@172.22.245.209>;tag=02ce0f281c92012893fde2af47c1b9e4000gtj3
Max-Forwards: 70
CSeq: 55527 OPTIONS
P-Charging-Vector: icid-value=g69mc046nhcs2p86ehc8jqo5i1cijgdc3rni3ro6vai05al8c272g420;icid-generated-at=172.22.245.209
Content-Length: 0
Apr 25 11:58:37: //-1/000000000000/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Apr 25 11:58:37: //-1/000000000000/SIP/Error/sipSPIUpdateCallInfo:
input argument error
Apr 25 11:58:37: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Apr 25 11:58:37: //13739/1C4F5127B667/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Apr 25 11:58:37: //13739/1C4F5127B667/SIP/Error/sipSPIUpdateCallInfo:
Apr 25 11:58:37: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
Apr 25 11:58:37: //13739/1C4F5127B667/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@6.6.92.1;tag=EF8ED0E-736
Date: Mon, 25 Apr 2022 09:58:37 GMT
CSeq: 55527 OPTIONS
Content-Length: 357
v=0
o=CiscoSystemsSIP-GW-UserAgent 9276 4108 IN IP4 6.6.92.1
s=SIP Call
c=IN IP4 6.6.92.1
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
c=IN IP4 6.6.92.1
m=image 0 udptl t38
c=IN IP4 6.6.92.1
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Apr 25 11:58:37: //13738/181BB940B660/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Contact: <sip:6.6.51.1:5062;transport=tcp>
CSeq: 101 INVITE
Content-Length: 210
v=0
s=-
c=IN IP4 6.6.51.1
t=0 0
a=fmtp:101 0-15
a=ptime:20
Apr 25 11:58:37: //13738/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Apr 25 11:58:37: //13738/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:7F8CEAA03330
Apr 25 11:58:37: //13738/181BB940B660/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_ADD_SE_IN_RESP, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:330
Apr 25 11:58:37: //13738/181BB940B660/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7F8CE92D3738
State of The Call : STATE_ACTIVE
TCP Sockets Used : YES
Calling Number : +33296086769
Called Number : +33296086772
Source IP Address (Sig 6.6.92.1
Destn SIP Req Addr:Port : 6.6.51.1:5062
Destn SIP Resp Addr:Port : 6.6.51.1:5062
Destination Name : 6.6.51.1
Apr 25 11:58:37: //13738/181BB940B660/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g711alaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 6.6.92.1
Source IP Port (Media): 8170
Destn IP Address (Media): 6.6.51.1
Destn IP Port (Media): 57444
Orig Destn IP Address:Port (Media): [ - ]:0
Apr 25 11:58:37: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
Apr 25 11:58:37: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Apr 25 11:58:37: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:7F8CEAA09C68
Apr 25 11:58:37: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_ADD_SE_IN_RESP, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:330
Apr 25 11:58:37: //13737/181BB940B660/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Contact: <sip:+33296086772@6.6.92.129:5064;transport=tls>
Supported: replaces
Supported: sdp-anat
Session-Expires: 3600;refresher=uac
Require: timer
Supported: timer
Content-Length: 571
v=0
s=SIP Call
c=IN IP4 6.6.92.129
t=0 0
a=ice-lite
c=IN IP4 6.6.92.129
a=mid:1
a=ice-ufrag:1rg1
a=rtpmap:13 CN/8000
a=fmtp:101 0-16
a=ptime:20
Sent:
ACK sip:6.6.51.1:5062;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 6.6.92.1:5060;branch=z9hG4bK120010D3
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 43ac6cb2eb565b6eb9d0e33a6b06746e;remote=7be33c3fdd115e5bb7effee29994ac66
Content-Length: 0
Apr 25 11:58:38: //13737/181BB940B660/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 571
v=0
s=SIP Call
c=IN IP4 6.6.92.129
t=0 0
a=ice-lite
c=IN IP4 6.6.92.129
a=mid:1
a=ice-ufrag:1rg1
a=rtpmap:13 CN/8000
a=fmtp:101 0-16
a=ptime:20
Apr 25 11:58:38: //13733/0A19C0C0B65C/SIP/Error/sipSPIFlushDeferredQueue:
Apr 25 11:58:40: //13737/181BB940B660/SIP/Error/act_sentsucc_wait_ack:
Out of retries
Apr 25 11:58:40: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
No Inbound Container Created !!!
Apr 25 11:58:40: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
Apr 25 11:58:40: //13737/181BB940B660/SIP/Error/sipSPI_ipip_ExtractAndAddPassthruCopyListDataToContainer:
Container is NULL
Apr 25 11:58:40: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
Corrupted/Freed Container=0x0
Apr 25 11:58:40: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Apr 25 11:58:40: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Apr 25 11:58:40: //13737/181BB940B660/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Apr 25 11:58:40: //13738/181BB940B660/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:6.6.51.1:5062;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 6.6.92.1:5060;branch=z9hG4bK12011470
Max-Forwards: 70
Timestamp: 1650880720
CSeq: 102 BYE
Reason: Q.850;cause=102
Content-Length: 0
Apr 25 11:58:40: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Apr 25 11:58:40: //13737/181BB940B660/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:api-du-c-euwe.pstnhub.microsoft.com:443;x-i=0702d4ae-cc70-47ac-a163-f1dcd9d4cb72;x-c=26bc3a05cc825a2d9e8752e0085d3280/d/8/ca53ba2a53064ff28b5601705ff77ab1 SIP/2.0
Via: SIP/2.0/TLS 6.6.92.129:5064;branch=z9hG4bK1202C6C
From: <sip:+33296086772@hq692gw.msvisit6.one.equant.net:5064;user=phone>;tag=EF8D1C3-16AD
To: "HQ692gw-teams1"<sip:+33296086769@sip.pstnhub.microsoft.com:5061;user=phone>;tag=ac87d0e19fde43efb68fe6ed361312e0
Max-Forwards: 70
CSeq: 101 BYE
Content-Length: 0
Received:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 6.6.92.1:5060;branch=z9hG4bK12011470;rport=40673
CSeq: 102 BYE
Content-Length: 0
Apr 25 11:58:40: //13738/181BB940B660/SIP/Call/sipSPICallInfo:
State of The Call : STATE_DEAD
Apr 25 11:58:40: //13738/181BB940B660/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Disconnect Cause (CC) : 102
Disconnect Cause (SIP) : 200
Apr 25 11:58:40: //13738/181BB940B660/SIP/Error/sipSPIFlushDeferredQueue:
Received:
SIP/2.0 200 OK
FROM: <sip:+33296086772@hq692gw.msvisit6.one.equant.net:5064;user=phone>;tag=EF8D1C3-16AD
TO: "HQ692gw-teams1"<sip:+33296086769@sip.pstnhub.microsoft.com:5061;user=phone>;tag=ac87d0e19fde43efb68fe6ed361312e0
CSEQ: 101 BYE
VIA: SIP/2.0/TLS 6.6.92.129:5064;branch=z9hG4bK1202C6C
CONTENT-LENGTH: 0
SERVER: Microsoft.PSTNHub.SIPProxy v.2022.4.18.2 i.EUNO.11
Apr 25 11:58:40: //13737/181BB940B660/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7F8CE92F8F88
Source IP Address (Sig 6.6.92.129
Destn SIP Req Addr:Port : 52.114.76.76:5061
Destn SIP Resp Addr:Port : 52.114.76.76:16576
Destination Name : 52.114.76.76
Apr 25 11:58:40: //13737/181BB940B660/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Address (Media): 6.6.92.129
Source IP Port (Media): 8168
Destn IP Address (Media): 52.113.227.8
Destn IP Port (Media): 51708
Disconnect Cause (CC) : 86
Apr 25 11:58:40: //13737/181BB940B660/SIP/Error/sipSPIFlushDeferredQueue:
5629: Apr 25 09:58:41.348: //13738/181BB940B660/
------------------ Cover Buffer ---------------
Search-key = +33296086769:+33296086772:13738
Timestamp = Apr 25 09:58:30.269
CallID = 13738
Peer-CallID = 13737
Correlator = 22
Called-Number = +33296086772
Calling-Number = +33296086769
SIP CallID = 181D66FA-C3B511EC-B6668EA1-83F540C@6.6.92.1
SIP SessionID = 43ac6cb2eb565b6eb9d0e33a6b06746e
GUID = 181BB940B660
5489: Apr 25 09:58:30.269: //13738/181BB940B660/CUBE_VT/SIP/MISC/Matched Dialpeer: Dir:Outbound, Peer-Tag: 300
5490: Apr 25 09:58:30.270: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_NONE, Next State = STATE_IDLE, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
5491: Apr 25 09:58:30.271: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_SET_MODE, Current State = CNFSM_CONTAINER_STATE, Next State = CNFSM_NO_STATE_CHANGE
5492: Apr 25 09:58:30.271: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_PRE_SETUP, Current State = S_SIP_IWF_SDP_IDLE, Next State = CNFSM_NO_STATE_CHANGE
5498: Apr 25 09:58:30.271: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_PEER_MULTIMEDIA_CHANNEL_IND, Current State = S_SIP_IWF_SDP_IDLE, Next State = CNFSM_NO_STATE_CHANGE
5499: Apr 25 09:58:30.271: //13738/181BB940B660/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type = voice-only, Stream State = STREAM_ADDING Negotiated Codec = No Codec , Negotiated DTMF Type = inband-voice, Stream Index = 1
5500: Apr 25 09:58:30.271: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_allocate_port (8170)
5501: Apr 25 09:58:30.271: //13738/181BB940B660/CUBE_VT/SIP/FSM/Media-State: Event = E_IPIP_MEDIA_SERV_EV_PEER_CHNL_IND, Current State = S_IPIP_MEDIA_SERV_STATE_IDLE, Next State = S_IPIP_MEDIA_SERV_STATE_INIT_XCODER_RESERVED
5502: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/MISC/Software-Error: Type: Error in Transcoder Reservation, Code-location:0x300408E
5503: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_CONTINUE_PRE_SETUP, Current State = S_SIP_IWF_SDP_IDLE, Next State = CNFSM_NO_STATE_CHANGE
5504: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_INIT_CALL_SETUP, Current State = S_SIP_IWF_SDP_IDLE, Next State = CNFSM_NO_STATE_CHANGE
5505: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_create_session (0)
5506: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_set_non_rtp_call (0)
5507: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
5508: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_update_interface_cac_resource (0)
5509: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_CC_CALL_SETUP, Current State = STATE_IDLE
5510: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_call_proceeding (0)
5511: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/FSM/Offer-Answer: Event = E_SIP_INVITE_SDP_SENT, Current State = S_SIP_EARLY_DIALOG_IDLE, Next State = S_SIP_EARLY_DIALOG_OFFER_SENT
5512: Apr 25 09:58:30.272: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_SENT_SDP, Current State = S_SIP_IWF_SDP_IDLE, Next State = S_SIP_IWF_SDP_SENT_AWAIT_SDP
5513: Apr 25 09:58:30.273: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_IDLE, Next State = STATE_SENT_INVITE, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
5514: Apr 25 09:58:30.273: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
5515: Apr 25 09:58:30.273: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_set_non_rtp_call (0)
5516: Apr 25 09:58:30.273: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
5517: Apr 25 09:58:30.274: //13738/181BB940B660/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 1800
Max-Forwards: 69
Content-Length: 386
v=0
s=SIP Call
c=IN IP4 6.6.92.1
t=0 0
c=IN IP4 6.6.92.1
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=label:main-audio
5520: Apr 25 09:58:30.301: //13738/181BB940B660/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
5521: Apr 25 09:58:30.301: //13738/181BB940B660/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_NEW_MESSAGE, Current State = STATE_SENT_INVITE
5522: Apr 25 09:58:30.301: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_SENT_INVITE, Next State = STATE_RECD_PROCEEDING, Current Sub-State = STATE_NONE, Next Sub-State = STATE_SETUP_BUFFERED
5523: Apr 25 09:58:30.319: //13738/181BB940B660/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 210
v=0
s=-
c=IN IP4 6.6.51.1
t=0 0
a=ptime:20
a=fmtp:101 0-15
5525: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_NEW_MESSAGE, Current State = STATE_RECD_PROCEEDING
5526: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/FSM/Offer-Answer: Event = E_SIP_INVITE_RESP_SDP_RCVD, Current State = S_SIP_EARLY_DIALOG_OFFER_SENT, Next State = S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE
5527: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_RCVD_SDP, Current State = S_SIP_IWF_SDP_SENT_AWAIT_SDP, Next State = S_SIP_IWF_SDP_DONE
5528: Apr 25 09:58:30.319: //13738/181BB940B660/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type = voice+dtmf, Stream State = STREAM_ADDING Negotiated Codec = g711alaw, Negotiated DTMF Type = rtp-nte, Stream Index = 1
5529: Apr 25 09:58:30.319: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_call_mode_update_ind (0)
5533: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_caps_ind (0)
5534: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_call_alert (0)
5535: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_RECD_PROCEEDING, Next State = STATE_RECD_PROCEEDING, Current Sub-State = STATE_SETUP_BUFFERED, Next Sub-State = STATE_SETUP_BUFFERED
5536: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_UPDATE_STREAM_CONTEXT, Current State = S_SIP_IWF_SDP_DONE, Next State = CNFSM_NO_STATE_CHANGE
5537: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
5538: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_PEER_CAPS_ACK,, Current State = CNFSM_CONTAINER_STATE, Next State = CNFSM_NO_STATE_CHANGE
5539: Apr 25 09:58:30.320: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_PEER_CAPS_ACK,, Current State = CNFSM_CONTAINER_STATE, Next State = CNFSM_NO_STATE_CHANGE
5551: Apr 25 09:58:30.323: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
5552: Apr 25 09:58:30.323: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_set_non_rtp_call (0)
5553: Apr 25 09:58:30.323: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
5554: Apr 25 09:58:30.323: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_bridge_done (0)
5555: Apr 25 09:58:30.323: //13738/181BB940B660/CUBE_VT/SIP/API: ccsip_bridge (0)
5564: Apr 25 09:58:37.349: //13738/181BB940B660/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 210
v=0
s=-
c=IN IP4 6.6.51.1
t=0 0
a=fmtp:101 0-15
a=ptime:20
5566: Apr 25 09:58:37.349: //13738/181BB940B660/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_NEW_MESSAGE, Current State = STATE_RECD_PROCEEDING
5567: Apr 25 09:58:37.350: //13738/181BB940B660/CUBE_VT/SIP/FSM/Offer-Answer: Event = E_SIP_INVITE_RESP_SDP_RCVD, Current State = S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE, Next State = CNFSM_NO_STATE_CHANGE
5568: Apr 25 09:58:37.350: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_RECD_PROCEEDING, Next State = STATE_RECD_PROCEEDING, Current Sub-State = STATE_SETUP_BUFFERED, Next Sub-State = STATE_NONE
5569: Apr 25 09:58:37.350: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_call_connected (0)
5570: Apr 25 09:58:37.350: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_RECD_PROCEEDING, Next State = SIP_STATE_RECD_SUCCESS, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
5571: Apr 25 09:58:37.350: //13738/181BB940B660/CUBE_VT/SIP/FSM/Offer-Answer: Event = E_SIP_DIALOG_ESTD, Current State = S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE, Next State = S_SIP_MID_DIALOG_IDLE
5572: Apr 25 09:58:37.349: //13738/181BB940B660/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_CALL_ACTIVE, Current State = CNFSM_CONTAINER_STATE, Next State = CNFSM_NO_STATE_CHANGE
5573: Apr 25 09:58:37.349: //13738/181BB940B660/CUBE_VT/SIP/FSM/Media-State: Event = E_IPIP_MEDIA_SERV_EV_CALL_ACTIVE, Current State = CNFSM_CONTAINER_STATE, Next State = CNFSM_NO_STATE_CHANGE
5574: Apr 25 09:58:37.350: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = SIP_STATE_RECD_SUCCESS, Next State = STATE_ACTIVE, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
5583: Apr 25 09:58:37.352: //13738/181BB940B660/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
5599: Apr 25 09:58:40.352: //13738/181BB940B660/CUBE_VT/SIP/FSM/Media-State: Event = E_IPIP_MEDIA_SERV_EV_XCODER_RESET_STREAM, Current State = CNFSM_CONTAINER_STATE, Next State = S_IPIP_MEDIA_SERV_STATE_IDLE
5600: Apr 25 09:58:40.352: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
5601: Apr 25 09:58:40.352: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_bridge_drop_done (0)
5603: Apr 25 09:58:40.355: //13738/181BB940B660/CUBE_VT/SIP/MISC/Call Disconnect: Initiated at: 0x260070A, Originated at:0x260070B, Cause Code = 102
5606: Apr 25 09:58:40.357: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_update_interface_cac_resource (0)
5607: Apr 25 09:58:40.357: //13738/181BB940B660/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_CC_CALL_DISCONNECT, Current State = STATE_ACTIVE
5608: Apr 25 09:58:40.357: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_ACTIVE, Next State = STATE_DISCONNECTING, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
5609: Apr 25 09:58:40.357: //13738/181BB940B660/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
5615: Apr 25 09:58:40.412: //13738/181BB940B660/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
5616: Apr 25 09:58:40.412: //13738/181BB940B660/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_NEW_MESSAGE, Current State = STATE_DISCONNECTING
5617: Apr 25 09:58:40.412: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_delete_dp_session (0)
5618: Apr 25 09:58:40.411: //13738/181BB940B660/CUBE_VT/SIP/API: cc_api_call_disconnect_done (0)
5619: Apr 25 09:58:40.411: //13738/181BB940B660/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_DISCONNECTING, Next State = STATE_DEAD, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
5620: Apr 25 09:58:40.412: //13738/181BB940B660/CUBE_VT/SIP/MISC/Error: sipSPIFlushDeferredQueue: Invalid deferredQueue
5621: Apr 25 09:58:40.412: //13738/181BB940B660/CUBE_VT/SIP/API: voip_rtp_release_port (8170)
5630: Apr 25 09:58:41.352: //13737/181BB940B660/
Search-key = +33296086769:+33296086772:13737
Timestamp = Apr 25 09:58:30.260
CallID = 13737
Peer-CallID = 13738
Correlator = 22
SIP CallID = 26bc3a05cc825a2d9e8752e0085d3280
SIP SessionID = 7be33c3fdd115e5bb7effee29994ac66
GUID = 181BB940B660
louisKl1
Ok problem was that my Contact header was not tanslated to the right format (CUBE behind behind a nat)
Teams would not answer with an ACK to my 200 Ok.
I don't know if that command is available on your platform (it might be hidden, as I do not see it in the running configuration), but try and set the option below (in global config mode I think):
ip rtcp report interval 6000
Also, I found the thread linked below:
https://techcommunity.microsoft.com/t5/microsoft-teams/failed-of-direct-routing-for-ms-phone-system-and-cisco-cube/m-p/1580154
Thank you for your help,
Previously configured was :
ip rtcp report interval 1200
I have tried both the following commands :
ip rtcp report interval 6000 - 65535
Both commands did not change anything, call stops after 2-3s.
I also checked the link and verified everything is correct.
louisKl1
