Cyrpto Connectivity...
kevin.atwood
I've got a crypto map setup and working fine to a client. On our side, we've got a NAT pool of 1 address that is PAT'ed so all traffic to their subnet is PAT'ed accross this IP.
I'm trying to allow access from another client who is connected via a crpto map, to the other client's subnets through the PAT'ed IP...but I'm not seeing any translations when trying to ping from the second client.
Has anyone been able to connect the two clients through this type of config?
Kevin
Richard Burts
Kevin
Does the address translation (NAT/PAT) use an access list to identify what traffic to translate? If so does that access list include traffic sourced from the second client as being permitted?
It might be easier to help you find a solution if you would post the parts of the configuration that deal with the translation (and perhaps the parts that deal with the encryption).
Rick
Rick
crypto map Client 15 ipsec-isakmp
description Client 1
set peer ***.***.***.70
set security-association lifetime seconds 86400
set security-association idle-time 86400
set transform-set rtpset vpnset
match address 116
crypto map Client 19 ipsec-isakmp
description Client 2
set peer ***.***.***.51
set transform-set vpnset
match address 120
ip nat pool nat-pool 172.23.2.7 172.23.2.7 netmask 255.255.255.0
ip nat inside source list 185 pool nat-pool mapping-id 10 overload
ip access-list extended 120
permit ip host 172.23.103.6 192.168.12.0 0.0.0.255
access-list 116 permit ip host 172.23.2.7 host 172.23.103.6
access-list 185 permit ip any 172.23.0.0 0.0.255.255
Oops...for got a reply with the config post...
Yes...any destined for the subnet going throught he PAT'ed IP.
Thanks for the reply.
Kevin
