DC N5K + catalyst device Management for a seprate Management VRF
lerner cisco
Hi All,
I would like to check with you all on the below design ,  suggestions would be great help
connectivity : Tacacse server---------> Router -----------> Nexus 5K--------> 3850 catalyst switch
design-  tacacs server  reachable  via Router ,
            Router Gi/0 connected to Nexus 5K eth1/1 ( L3 port , and part of Management VRF)
            nexus 5K management VRF configured
             Nexus 5K access port  Eth1/2 ( vlan2, also configued under vrf Mgmt) connected to Access port vlan 2 at 3850 Gi 1/0/48
 .SO here I have question , the Nexus connected port Ethernet 1/2  to catalyst 3850 ( configured as access port ) should also call under VRF Mgmt , or it need to keep only access port
interface Ethernet1/2
 des Mgmt_3850 sw  Gi 1/0/48
 vrf  member MGMT
switch mode access
switchport access vlan 2
------or ---------
switch mode access
Router config
Int gi0/0
ip address 10.10.10.1 25.255.255
desc Nexus 5K
no shut
Nexus PRIMARY - configuration
interface Ethernet1/1
ip address 10.10.10.2 25.255.255
vlan 2
 name Management
vrf context MGMT
 ip route 0.0.0.0/0 10.10.10.1 ( Pointed router LAN port )
interface Vlan2
 vrf  member MGMT
 des MGMT
 ip address 10.200.238.2/29
 hsrp version 2
  hsrp 200
    preempt
    priority 150
    ip 10.200.238.1
  no shutdown
 vrf  member MGMT
switch mode access
no shut
3850 switch config
interfaceGi1/0/48
 des Nexus Mgmt Eth 1/2
switch mode access
default gateway 10.200.238.1
lerner cisco
got a solution - no need configure  vrf  member MGMT on the nexus ports ,3850 connected switches.
Since you are using a different port (e1/2)than the actual management (mgmt0) than there is no  need to put that port in a vrf.
