DCHP server on CBS350 switch
IanGrundling
I just want to know if it is possible to have a CBS350 switch on a network, then have the CBS350 switch be a DCHP server.
Our scenario is we have different meeting rooms and AV equipment in those rooms including the CBS350. We have a processor for the AV equipment in each room which needs to be on the corporate network as well as the CBS350 switch, and the other equipment needs to get addresses from the switch and still be able to communicate to the processor.
I don't know if this is possible to do, if the processor needs to be on the DHCP of the CBS350 that is also fine, it makes more sense to me to do it that way, but the processor still needs to have internet access in order to send data to a cloud management platform.
5 Replies 5
Richard Burts
There are things about your network that we do not know and which might affect our advice. But fundamentally I believe the question is whether you can implement DHCP server on CBS350 and the answer is yes that is supported on that switch.
Rick
 I hope this will help, so the blue connecting lines is devices that needs to get their addresses form the corporate network and the devices with the black connecting lines needs to be on the DHCP of the switch but still be able to communicate with the processor.
Hello
based on you diagram then yes it would be applicable to have the switch run dhcp service however if both blue and black need to communicate with each other and blue is currently receiving address allocation from corporate dhcp server then why cannot black users also receive dhcp allocation from corporate dhcp server?
Kind Regards
Paul
Am I correct in assuming that the blue line is one vlan/one subnet and the black line is a different vlan/subnet? if so will the inter vlan routing be done on the CBS350 or on the upstream device?
Rick
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/Administration-Guide/cbs-350/ipv4-configuration.html#ID-00001836
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
