NAT destination based on match between source and destination IP
iotea
I am searching for days now, but I can't figure out what to do.
This is what I try to achieve:
PC1 sends packet from IP 10.155.0.26 with destination 100.100.100.100
Router1 receives packet, confirms it is from ip 10.155.0.26 with destination 100.100.100.100 and changes destination to 192.168.114.14
But only when source IP 10.155.0.26 and destination 100.100.100.100 are in this combination.
Is this possible with a router?
I did it once on an Asa while using ASDM, then it looks like this:
** In the image source and destination are "provider", in my case now source is Inside and Destintion is Outside
6 Replies 6
Hello
Yes it is possible, Can you confirm what rtr your are using?
Do you have to it CLI?
Example:
Interface x/x
description LAN port
ip nat inside
Interface x/x
description WAN port
ip nat outside
conf t
ip nat inside source static 10.155.0.25 100.100.100.100
Kind Regards
Paul
Hello Paul,
Thank you for your answer, I use an vIOS router.
With the example given, it translates the source nat 10.155.0.25 to 100.100.100.100 right?
Hello
Yes it will
Kind Regards
Paul
balaji.bandi
adding to other post check below couple of examples and explanation :
https://www.practicalnetworking.net/stand-alone/cisco-asa-nat/
BB
Thank you for your answer, but that is how to configure it on Asa. I already did that, I am looking for how to do this on a router.
So you looking redirection
PC1 10.155.0.26 destination 100.100.100.100
you want to redirect to next host 192.168.114.14  or change the source address 10.155 0.26 to 192.168.114.14 ?
BB
