DDNS Not Updating by Itself
rommelotero
Hi everyone
I have this Router connected to an ISP which give a dynamic IP
I have done the DDNS config on my router to update when it changes, the problem is that is not happening by itself, I mean I have to either turn off and on the interface or fisically unplug and plug again the ethernet cable so it loses the IP learned and takes the new one and then It does the process that comes with it
It this right? am I missing something?
here my config
ip ddns update method no-ip
 HTTP
  add http://***USER AND PASSWORD***@dynupdate.no-ip.com/nic/update?hostname=<h>&myip=<a>
 interval maximum 0 0 5 0
interface GigabitEthernet0/0
 description ABA
 ip ddns update hostname ***HOSTNAME***
 ip ddns update no-ip
 ip address dhcp
any suggestion?
13 Replies 13
I think under the update method, you are missing 'ddns' and 'internal'
ddns (if you specify 'both', both the A and PTR RRs are update)
internal
HTTP
description ABA
ip address dhcp
internal
HTTP
description ABA
ip address dhcp
Thanks for your aswers but I cant put that because Im already using HTTP method and if I try it give me this
Only one dynamic DNS update type is allowed in a method.
sorry about that, you cannot use both, you would have to disable HTTP first, but that probably wouldn't work
What does the rest of your configuration look like ? Do you get an IP address through DHCP ? If so, check if 'ip dhcp-client update dns' is configured.
Also, do you have:
ip dns server
ip name-server 8.8.8.8
ip name-server 8.8.4.4
configured ?
hostname INTERNET-UCS
ip dhcp excluded-address 192.168.10.3
ip dhcp pool INTERNET-UCS
   network 192.168.10.0 255.255.254.0
   default-router 192.168.10.3
   dns-server 192.168.10.3
   lease 0 8
 HTTP
  add http://***user and password***@dynupdate.no-ip.com/nic/update?hostname=<h>&myip=<a>
 description ABA
 ip ddns update hostname ***hostname***
 ip address dhcp
 ip access-group 120 in
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description Internet-UCS
 ip address 192.168.10.3 255.255.254.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 10 interface GigabitEthernet0/0 overload
access-list 10 permit 192.168.10.0 0.0.1.255
access-list 120 remark "Block 53 External Query"
access-list 120 deny   tcp any any eq domain
access-list 120 deny   udp any any eq domain
access-list 120 permit ip any any
I don't know how the access list you have applied to the external interface affects the dynamic dns updates, remove it and check if that makes a difference...
description ABA
ip address dhcp
--> no ip access-group 120 in
ip nat outside
duplex auto
speed auto
It does not affect
I recently added this ´cause some warnings about DNS querys I was getting from outside because 8.8.8.8
but before that It was the same behaviour
try and give the router a reboot (if you have not already done that) and check if that makes a difference...
still the same
actually, I think you are supposed to shut/no shut the interface for NO-IP to do the job.
You can automate this by configuring archive logging and a small EEM script. The script will run every time you change the hostname.
archive
 log config
  logging enable
  notify syslog
  hidekeys
event manager applet SHUT_NO_SHUT
event syslog pattern "hostname"
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface GigabitEthernet0/0"
action 4.0 cli command "shut"
action 5.0 cli command "no shut"
action 6.0 cli command "end"
archive
 log config
  logging enable
  notify syslog
  hidekeys
woo to be honest I didn´t knwo you could do that!
but that makes a question to come up. If I understood the script it will execute once the logs show a change on my hostname right?  but how will that change If it does not change IP without doing the shut/no shut operation? I dont know if you get the idea of my question..
not sure if I understand your question...the script will shut/no shut the interface whenever the hostname changes. That should, at least that is how I understand the update process to work, update the DNS...
I just apply your solution...
I´ll come back to say if it works, thank you
Hey there, Thanks  it worked
