Is there anything to consider when upgrading from ASr9000 OS 4.3.4 to
rjh0908
The module is RSP440-TR and the current version is 4.3.4
The client is currently using Telnet and Password md5 formats.
You need to upgrade to use SSHv2 and algorithm (sha-256/512).
Equipment Sw and Hw can not be guaranteed when upgrading from Cisco to EOS / EOL
Is there anything to note or refer to when upgrading?
 Are you running version 4.3.4 and planning to go to which version? As per the docs, RSP440-TR would be supported in 4.2.0 version only.
Table 4.    Ordering information
Product Description
Supported Software Release
Part Number
Route Switch Processor optimized for packet transport
Cisco IOS XR Software Release 4.2.0 onwards
A9K-RSP440-TR
Route Switch Processor optimized for packet transport, spare
A9K-RSP440-TR=
Route Switch Processor optimized for service edge
A9K-RSP440-SE
Route Switch Processor optimized for service edge, spare
Cisco IOS-XR Software Release 4.2.0 onwards
A9K-RSP440-SE=
Route Switch Processor with 180 G/slot upgradeable to 440G/slot Fabric
Cisco IOS-XR Software Release 5.3.0 onwards
A9K-RSP440-LT
Is the ASR9000 device compatible with 440G-TR and 440G-LT?
The goal is to upgrade from 4.3.4 to 5.3.4
It is compatible with 440G-LT.
But, for 440G-TR I dont think you can go to 5.3.4.
Product Description
Part Number
A9K-RSP440-TR
A9K-RSP440-TR=
Are SHA-256 / 512 available in version 5.3.4???
And is theA9K-RSP880-TR/LT compatible with the ASR 9006 AC Chassis with PEM Version 2 model?
