DDR: Secondary Address on Dialer problems...
mmusacchio
For doing DDR, the normal configuration we are using is this:
Standard configuration
interface BRI0
description isdn 073453545
no ip address
encapsulation ppp
no ip mroute-cache
dialer rotary-group 1
isdn switch-type basic-net3
no cdp enable
interface Dialer1
ip address 172.31.5.x 255.255.255.128
encapsulation ppp
dialer in-band
dialer idle-timeout 300
dialer map ip 172.31.5.1 name e-nash number 1
dialer map ip 172.31.5.1 name e-nash number 2
dialer map ip 172.31.5.1 name e-nash number 3
dialer map ip 172.31.5.1 name e-nash number 4
dialer load-threshold 10 either
dialer-group 1
no cdp enable
ppp authentication chap
ppp multilink bap
ip route 0.0.0.0 0.0.0.0 172.31.5.1 200
E-NASH router (C7500 - IOS 12.1.22b)
interface Dialer1
ip address 172.28.34.1 255.255.255.0 secondary
ip address 172.31.5.1 255.255.255.128
encapsulation ppp
load-interval 30
dialer in-band
dialer map ip 172.31.5.b name X-SITE number
dialer-group 1
no cdp enable
ppp multilink
ip route (X-SITE network) to 172.31.5.b
The problem starts when I change the dialer network on one site.
E-SITE (C2811 - IOS 12.4.13b)
interface Dialer1
ip address 172.28.34.2 255.255.255.0 <- New address pool (secondary on E-NASH)
encapsulation ppp
dialer in-band
dialer map ip 172.28.34.1 name e-nash number 1
dialer map ip 172.28.34.1 name e-nash number 2
dialer map ip 172.28.34.1 name e-nash number 3
dialer map ip 172.28.34.1 name e-nash number 4
dialer-group 1
no cdp enable
ppp multilink bap
ip route 0.0.0.0 0.0.0.0 172.28.34.1 200
On nash router:
Dialer1
dialer map ip 172.28.34.2 name E-SITE number
ip route (E-SITE network) to 172.28.34.2
E-NASH has the 172.31.5.x as primary, we have 70 sites connected in ISDN on that network
backup and the 172.31.5.x is exausted, so I have to use the new 172.28.34.x.
I got some packet loss when I ping from E-SITE to the ethernet of the E-NASH router and I have seen the E-NASH
appears ever with the primary address (172.31.5.1).
The problem seems to be random, and if I ping from E-SITE to a router behind E-NASH seems to respond ok.
Using the network 172.31.5.x there is no problem of packet lost when I Ping, the problem is present only
with the new network.
At this point is it possible a problem with the IOS on NASH router? or is there another possibility
to use a secondary interface using dial map?...
Best Regards!
a-vazquez
Level 6
Level 6
Backup initialization is linked to the dynamic routing protocol, rather than a specific interface or static route entry. Therefore, both primary and backup interfaces can be any interface type, and can be used across multiple interfaces and multiple routers. Dialer Watch also relies on convergence, which is sometimes preferred over traditional DDR links
