DEBUG BGP clearing my Show logging ASR9904
okochat18
Hello Community Members
I have a question about debug BGP!
When I execute "debug BGP" and do the "show logging" on a ASR9904.
After which make an event that triggers loggging, e.g. Interface down or logging into Device via ssh;
and then  I do "show logging" I discovered that the loggings all disappear?
Anybody experienced? this and how did you handle it?
Please note that when I do "undebug BGP", the show logging recovers and can now see events that have occured only after that undebug command
M02@rt37
Hello @okochat18
Adjust the buffer size as a first step. The issue likely occurs because debug bgp  generates a high volume of logs, overwhelming the logging buffer and causing other messages to disappear.
Best regards
okochat18
Thanks for the response.
At first I thought so too, but the logging buffer is currently set to logging buffered info and logging buffered size is about 2million
Thoughts?
Instead of sending debug logs to the buffer, redirect them to another destination: for example: Syslog /
Thanks!
