02-28-2006 06:06 AM - edited 03-03-2019 11:54 AM
Hi all
iam designing some network in my site, before that i want ask you some question about decreasing or hiding hops
my network looks like below
Internet
Core Router
Switch with VLAN
Router with QOS / Firewall
Customer edge Router
Customer Router
So when the customer tracing he need to cross all the places like
customer router---customer edge router--firewall--internerouter--internet
How can i make the connection to custome
and hide all the routes . he should be able to visual only internet router only
how can i achive this
advice will be great
ram
02-28-2006 11:56 AM
Hi Ram,
One option is to create ACLs on your routers that block ICMP time-exceed messages with a local router-address. That way, only asterisks (*) will appear for your internal routers when the customer does a traceroute. Note that outbound ACLs do not affect packets generated by your router so you will have to be careful about where you place the ACLs.
Hope that helps - pls rate the post if it does.
Paresh
03-01-2006 05:02 AM
thanks, but i dont see the reply will do a job
if the * comes
customer feel that packet Loss
so iam exploring methods
ram
03-01-2006 05:05 AM
If that is what you want, you will need to configure tunnels or run MPLS within your network so that the TTL of the packets is not decremented along your internal routers.
Paresh
