Default gateway on different subnet
duartesss
I have the following topology:
_______________________
| VPN Clients
192.168.0.x
192.168.0.100
|Cisco VPN Concentrator
172.16.2.100
172.16.2.200
|Cisco PIX Firewall --- Internet
172.16.30.200
172.16.30.150
| ISA Server
Internet
- At the Cisco Pix Firewall the default gateway is the Internet
- At the ISA Server the default gateway is the Internet
- At the Cisco VPN COncentrator I want to add the following route:
route to 172.16.30.150 mask 255.255.255.255 gateway 172.16.2.200
- At the Cisco PIX Firewall I want to add the following route:
route to 172.16.30.150 mask 255.255.255.255 gateway 172.16.30.150
After I add these two routes can I add the following route at the Cisco VPN Concentrator?:
route to 0.0.0.0 mask 0.0.0.0 gateway 172.16.30.150
With this route I will set the Cisco VPN Concentrator default gateway to the IP address interface at the ISA Server.
The default gateway is on a different subnet but, with the 2 routes explained above, the Cisco VPN Concentrator will know the path to the interface at the ISA Server.
I want to do this, because VPN Clients must be ISA NAT Clients and must connect to the Intern trough the ISA and not trough the PIX.
Duarte S.
PS - I know that I will need to add more routes, because the replies must know how to go from the ISA to the VPN Clients. I didn´t explain these routes here because they are not relevant to the main question: Can I have a default gateway on a different subnet if I add the necessary routes to that gateway?
tcordier
Hi Duarte,
your setup should work provided you use a subnetmask of /24 for the 172.16.2.100 on the VPN Concentrator and the 172.16.2.200 on the PIX. Alternatively, you could use
on the VPN Concentrator.
Also, your suggested route entry on the PIX
is not needed. The PIX does know the route to 172.16.30.150 as this is a connected subnet (I assume here that you use 172.16.30.128/25 or larger on the PIX; if that is not true, the route is required).
HTH, Thomas
Thanks for you reply.
In attach I send the diagram.
About the route:
I did'nt wrote correctly the route. I want to add the following route at the pix:
route to 172.16.30.0 mask 255.255.255.0 gateway 172.16.30.150
duartesss
About the route:
