Default metric when redistributing the default route into OSPF
Paheeradan Nagulan
I was looking at couple of cisco articles and they happened to mention that the default Metric when redistributing the default route from IGP/Static into OSPF is "20". But when I did a LAB in GNS3, it showed me a metric of "1". Which one is accurate?
Here is the output of "show ip ospf database external"
LS age: 1
Options: (No TOS-capability, DC, Upward)
LS Type: AS External Link
Link State ID: 0.0.0.0 (External Network Number )
Advertising Router: 30.0.0.2
LS Seq Number: 80000006
Checksum: 0x1677
Length: 36
Network Mask: /0
Metric Type: 2 (Larger than any link state path)
MTID: 0
Metric: 1
Forward Address: 0.0.0.0
External Route Tag: 1
friend he talking about redistribute prefix and the default metric ospf add into these prefix
it not talk about default route
default route always use 1
where other prefix when redistrubte into ospf it may have
1 if it from BGP
20 if it from static or other IGP
15 Replies 15
Hello
Apologies but you cannot redistribute a default route into ospf, this is performed via the default-information originate feature in the ospf process.
However for a default route to be entered in the ospf DB the advertising rtr needs to either have a static default route, just like you have mentioned in its route table first or you can "always" advertise a default route using the same command as above but the "always " keyword" appended.
Note -  this default route advertisement even though classed as external route like a redistributed route will not have the same metric cost as that of a redistributed E1/2 route but it will by default perform the same such that an E2 route by default (metric1) or E1 route (metric 2)
Kind Regards
Paul
Hi @paul driver ,
Yes, when I meant redistributing the default route into OSPF, i meant it by issuing the command "default-information originate". Like you said, in my lab I saw E2 with a metric of 1 . So  cisco article I was referring to needs to get updated. Thank you for answering my question!
I will check this in lab
MHM
@Paheeradan Nagulan
Are you refering to this?
How your OSPF got the route? Was from BGP? Or is It redistributing to BGP?
"Note: If a metric is not specified, OSPF puts a default value of 20 when it redistributes routes from all protocols except Border Gateway Protocol (BGP) routes, which gets a metric of 1"
Hi @Flavio Miranda ,
Here are the answers to your questions.
1)Are you refering to this?
Yes, I was referring to that specific document.
2)How your OSPF got the route? Was from BGP? Or is It redistributing to BGP?
I did multiple ways(Redistributing from EIGRP to OSPF , Creating a dummy default route, Added default-information originate always). It was showing the metric of 1 in those scenarios!
I run lab
in R1 if default route from static or from bgp in R3 the metric is 1
for your case can I see cisco doc. talking about 20 ?
@MHM Cisco World ,
Yes, I see Cisco have mentioned default metric =1 and the  default metric type = 2 in your link. Not sure why they have mentioned differently in the other document. Anyways thank you clearing up my doubt.
Hi @MHM Cisco World ,
First of all, thank you for taking your time to spin up a lab to test it. Yes, I did see the same behavior(The metric of 1).
Here is the doc that is talking about the metric of 20. May be Cisco is having some inconsistency about this.
https://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/8606-redist.html
Specifically here is the line I was referring to in that doc.
"Note: If a metric is not specified, OSPF puts a default value of 20 when it redistributes routes from all protocols except Border Gateway Protocol (BGP) routes, which gets a metric of 1."
Get it let me check one point
MHM
1 if it from BGP
Ah, didn't think about redistributing the specific prefixes. I need more coffee lol  . Yes, you are right. It makes perfect sense now. Thanks for the explanation!
Hello
@Flavio Miranda @MHM Cisco World  I would say its irrelevant how the default is originated for an default opsf route to be advertised into opsf then my understanding its mainly performed with the default-information originate command (excluding using network 0.0.0.0) appended into the opsf process. but with a default metric-type of E2 or a metric-type of E1 UNLESS it also with own seed metric appended to either.
Kind Regards
Paul
Hello
What you see is correct - if you think about it - its being injected locally by the rtr so the metric will be 1 by default metric-type 2 if you set it to type-1 it will increase due to link cost being added -
additionally if you add you own seed metric to the originate that will become the default value
Kind Regards
Paul
