Default root and show ip route x.x.x.x
grichardson661
Hi there,
Got this routing problem in my lab at home and looking for some advice.
I have 3 routers R1 > R2 > R3. R3 is the end router advertising a default root via RIP v2. All 3 routers are running classless routing.
All routing between subnets is working a treat. Below is an extract of the routing tables from each router.
R1
Gateway of last resort is 10.151.2.1 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
R 10.149.3.0/24 [120/2] via 10.151.2.1, 00:00:21, Serial0/0
R 10.149.2.0/24 [120/2] via 10.151.2.1, 00:00:21, Serial0/0
R 10.150.2.0/30 [120/1] via 10.151.2.1, 00:00:21, Serial0/0
C 10.151.2.0/30 is directly connected, Serial0/0
C 192.168.1.0/24 is directly connected, FastEthernet0/0
R* 0.0.0.0/0 [120/2] via 10.151.2.1, 00:00:21, Serial0/0
R2
Router with up/up interface 10.151.2.1
Gateway of last resort is 10.150.2.2 to network 0.0.0.0
R 10.149.3.0/24 [120/1] via 10.150.2.2, 00:00:27, Serial0
R 10.149.2.0/24 [120/1] via 10.150.2.2, 00:00:27, Serial0
C 10.150.2.0/30 is directly connected, Serial0
C 10.151.2.0/30 is directly connected, Serial1
R 192.168.1.0/24 [120/1] via 10.151.2.2, 00:00:27, Serial1
R* 0.0.0.0/0 [120/1] via 10.150.2.2, 00:00:27, Serial0
R3
Router with up/up interface 10.150.2.2
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
86.0.0.0/30 is subnetted, 1 subnets
C 86.54.12.56 is directly connected, Ethernet0
C 10.149.3.0/24 is directly connected, Loopback2
C 10.149.2.0/24 is directly connected, Loopback1
R 10.151.2.0/30 [120/1] via 10.150.2.1, 00:00:07, Serial0
R 192.168.1.0/24 [120/2] via 10.150.2.1, 00:00:07, Serial0
S* 0.0.0.0/0 is directly connected, Ethernet0
If i run a 'show ip route 25.25.25.5 from any router i receive a message stating the network is not in the table, which i dont understand, i thought the default route takes care of this? depending on classful/classless routing.
Also, if i run a tracert www.cisco.com from a host off R1 i see routes the packet is taking. See below.
1 <1 ms <1 ms <1 ms 192.168.1.1
2 23 ms 23 ms 23 ms 10.151.2.1
3 47 ms 44 ms 44 ms 10.150.2.2
So how come, when using a show ip route from the IOS it returns - network not in table even though the packet is being routed?
Any advice would be great!
Cheers,
Garry
Giuseppe Larosa
Hello Garry,
what you see is normal: when you do sh ip route 25.25.25.5 the router will look to find a match in the ip routing table.
If there isn't a prefix in the routing table the answer is the one you see.
With a single notable execption: the net 0.0.0.0/0 is never considered a match for a prefix.
By the way, sh ip route 0.0.0.0 provides a result only when a default route is present in the routing table.
I usually do this way
sh ip route x.x.x.x
if the answer is not in table I check if there is a default with
sh ip route 0.0.0.0
Hope to help
Giuseppe
Giuseppe Larosa
Hello Garry,
sh ip route x.x.x.x
sh ip route 0.0.0.0
Hope to help
Giuseppe
Giuseppe, this is great! exactly what i was looking for. thanks!
