Default Route to Loopback 1
NorthNW
Community Member
Hi there,
I'm currently setting up a network for a small local business with the topology seen below. The IT manager of the company specifically asked me to create default routes to be directed to Loopback 1 on ipv4 and ipv6. I can't seem to get it to work and there's no other router in this network. Any ideas?
Loopback 1 ipv4: 209.165.201.97 255.255.255.224
Loopback 1 ipv6: 2001:db8:acad:3f::1/64
@NorthNW try
#ip route 0.0.0.0 0.0.0.0 lo1
Good luck
KB
HI @NorthNW  is this real network plan? what is the purpose of setting
default route
towards loopback? what is the error you are getting when configuring
default route
Good luck
KB
Hi @Kasun Bandara
This is a real network, I used Packet Tracer as a simulation for my own purposes and also to show what I'm talking about. I'm not entirely certain why the IT manager has asked me to
default route
to Loopback 1, but he made it a mandatory objective for the job, and I'm not quite at the level to argue with him at the moment.
I'm currently using (please correct me if I'm wrong here):
Router0 (config)# ip route 0.0.0.0 0.0.0.0 209.165.201.97
%Invalid next hop address (it's this router)
Router0 (config)# ipv6 route ::/0 2001:db8:acad:3f::1
% Not allowed to point static routes through yourself
@NorthNW try
Good luck
KB
It looks like that worked out. Thank you for your help! I'll update if it doesn't end up working out.
