Default username/passcode does not work?
1953drtelco
Community Member
Ok...I'm trying to setup my 851W  router.  Unable to gain access from the LAN port on 10.10.10.1   I'm able to access through the console port, but the default username/passcode  (cisco/cisco) does not work.  I've tried the reset button, but still no luck.  This was a brand new unit with full documentation, but no luck in gaining access....Any ideas???
Leo Laohoo
Username/Password is Cisco/Cisco.
6 Replies 6
Leo Laohoo
Any other suggestions....Cisco/Cisco doesn't work....I keep getting the same response % Authentication failed.  Is there a procedure on a power reset to place it back on default?
I tried this once, but it didn't work....I tried a power reset with the reset button
pushed in.  After about 15 seconds of holding down the reset button
the router reset to default....yeah it worked and I'm able to program the router, thanks for you assistance...
Leo Laohoo
Thanks for the rating.
floriancalin69661
Community Member
i have cisco model rv130w and have the same problem .the pasword not work
default username/password for the RV130W is:
Username: Admin123
Password: Admin123
Did you try those ? If it doesn't work, check the link below:
https://www.192-168-1-1-ip.co/router/cisco/rv130/10428/#:~:text=Type%20192.168.,The%20default%20password%20is%20Admin123.
