Design issue with OSPF
kreinz.robert
Hi all,
I have following problem and I am not sure if I can solve this:
I have two Backbone Routers (Area0) and they are connected to a NSSA area. The NSSA area is connected in a "chain" starting from the first Backbone Router and terminating at the second one.
The issue I have is the traffic going inside, from Area 0 to the NSSA area. The backbone routers are routing all traffic directly to the connected NSSA area, even if the cost through Area0 and the second Backbone Router would be better for some destinations.
Is there any chance to overcome this issue?
Thanks in advance,
Robert
2 Accepted Solutions
Robert
You have encountered one of the principles of OSPF. An OSPF router will always prefer an intra-area route (route within the area) to an inter-area route (route between areas). When an OSPF router is making a routing decision and has a choice of an intra-area route and an inter-area route it will choose the intra-area route without any consideration of metrics or anything else. I do not know of any way to change this behavior.
Rick
Rick
Hi Robert,
http://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a0080094704.shtml#q13
The suggestion is: use two OSPF processes. But pay attention!
Andrea
5 Replies 5
ariela
Level 4
Level 4
Hi Robert,
if I well understand, your NSSA ABR choose external route instead of internal, isn't it?
please post your IOS versions (NSSA ABR).
Andrea
Hi Ariela,
The NSSA ABR has IOS 12.2(25)S9 (7304 NSE100)
It's the other way around:
The NSSA ABR choose always the directly (internal) way through the connected NSSA Area instead using the external way through area 0 to the second NSSA ABR, where the costs to reach the destination are better.
Robert
Robert
Rick
Rick
Hi Robert,
Andrea
Thanks all for the useful replies!
Robert
