DHCP==IP Assignment issue
sameermunj
i am using cisco 871 router for wireless connectivity.the ethernet port is connecte to lan and users are connected to wireless interface.problem is users are getting connected to wireless network but not getting ip address from dhcp server.dhcp server reeachable from lan.even tried using internel dhcp server.if we connect teh laptop to ethernet port of the router,the laptop is getting ip from dhcp server but its not happeneing on wireless.
anyone can help on this.present config attached.
Giuseppe Larosa
Answered in LAN forum.
Let's go on there.
Best Regards
Giuseppe
Actually i was confused on which forum will be exactly suitable for this particular query so i kept it on lan/wan as well as on wireless.anyway we will get the result shortly.hope it will work.
thanks
