DHCP relay over MPLS network
Beaurr
I have several branch connected in MPLS.
Branch A ( main branch, with 2 DHCP servers)
Branch B ( without DHCP server).
I would like to use DHCP servers on branch A to distribute IP adresses on branch B.
I asked to my operator to set up dhcp relay because I can't make modification myself on the ISP router.
But i was still able to obtain the configuration files of the 2 ISP routers ( A and B), and i see that they put the DHCP relays on interface 0/0 on router A ( main branch).
interface GigabitEthernet 0/0
ip address x.x.x.x  255.255.255.0
no negotiation
duplex full
speed 1000
ip helper-address 10.39.1.223  ==>My first DHCP server
ip helper-address 10.39.1.224  ==>Second DHCP server
description *** LAN CLIENT ***
Does the configuration have to be applied on the main router ( A) or on the remote branch router (B) or the two?
You would only need the DHCP relay at branch B. The interface that will need the configuration is the one facing the core switch at the branch where the client traffic will come. You wold need reachability to the DHCP server from branch B, so make sure you have that.
16 Replies 16
Jon Marshall
Assuming this is a L3 MPLS network then you need the "ip helper-address ..." command(s) on the L3 interface(s) for the clients on router B.
Jon
http://wonderdam.altervista.org/blog/vpls-basic-info-1/?doing_wp_cron=1655231157.1057639122009277343750
I am now 90% sure it l2vpn why?
You traffic from site b will l2 bridge to site A and there you will set
ip dhcp helper
Because site a svi is the gw for all client in site b
Please take look on this link
How bridge domain is use.
I'm not a specialist, but for me :
Layer 2 VPNs virtualize the datalink layer (Layer 2) so as to make geographically remote sites look as if they were operating in the same LAN network.
Layer 3 VPNs virtualize the network layer (Layer 3) so as to route your customer networks over a public infrastructure like Internet or Service provider backbone.
The actual commercial name of my operator offer is "Business VPN", and for me it's a L3VPN, or maybe a mix of the 2 ( it's possible?) but maybe I'm wrong.
I'll call my provider to tell me if it's a L3VPN or L2VPN offer
Hello @Beaurr ,
regardless of the type of MPLS service the routing is present.
The DHCP helper address is needed on each remote site at LAN interface level on client facing interfaces to translate a non routable broadcast BOOTPS request of the new client on a routable packet with destination = DHCP server and
gi-address field = LAN IP address
that received the original broadcast message.
The
gi-address
field helps the centralized DHCP servers to pick a free address from the correct DHCP scope / pool and the DHCP server sends back to the
 gi-address
their answer that is then relayed as a BOOTP message to the requester.
DHCP snooping if enabled can create issues when it sees a non empty
gi-address
field ( example WLC uplinks)
Hope to help
Giuseppe
Hello Giuseppe Larosa
So, I have to add the dhcp relays on the interface of the 2 routers? A and B? On the LAN interface? or just on the B, as Jon Marshall said?
On Router A :
no negotiation
duplex full
speed 1000
and on router B :
interface GigabitEthernet 0/1
no ip address
bridge-group 1
service-policy input COS-IN
service-policy output REMARK-DSCP
exit
And for MHM Cisco World, The provider told me that "business VPN" is an L3VPN
I will have 4 local VLAN on site B
Ex :
VLAN 10
name DATA
Ip address 10.60.133.253 255.255.255.0
Do i have to add the IP Helper Adress in each vlan too like this?
yes, thanks. The DHCP servers are in the 10.39.1.0 subnet on site A. This subnet include all the servers an can be reached from site B.
traceroute ok in both direction!
I think you misunderstand here,
he need to config
ip helper
under each SVI (VLAN) because this will receive the DHCP broadcast from client and forward it to central site.
https://www.expertnetworkconsultant.com/configuring/how-to-configure-a-dhcp-server-on-a-hypervisor-as-an-ip-helper-on-a-layer-3-switch-for-a-number-of-vlans/
Branch B is probably a normal branch with a Router on one interface facing the MPLS of the service provider but also another interface facing the CORE switch at the branch. That router is the default gateway for that branch and for that reason is where the
ip helper
must be configured.
I ask him before he sure that this is l3vpn,
So each client have defualt gateway which is svi in branch B,
And since svi is defualt gateway then he need to config
ip helper
in each svi in branch B
The traffic will flow as below,
Client send broadcast dhcp ask ip
Svi receive this broadcast convert it to unicast send it to central site
Reply from central will reply and this reply will forward to cleint.
So in each SVI.
And it is not router it is l3SW with multi vlan, this l3sw connect to central site via mpls l3vpn.
Hello MHM Cisco World
yes that's it. I created 4 VLANS on L3 Switch on branch B. with theirs different ip interface for each VLAN.
The DHCP server is on site A, the 2 are connected via an MPLS L3 VPN.
So, if i understand correctly, I have to ask the operator to configure ip helper on the LAN interface of their router (branch B).
AND
Me, I have to add the ip helper on each VLANS ont the L3 switch of branch B
VLAN 10
name DATA
Yes you need that, each SVI will receive the broadcast from client in that VLAN and use IP helper IP to build UNICAST toward the dhcp server which is in site A.
