DHCP through DSLAM Huawei MA5300
I have a Cisco Router 877 connected by the ADSL interface to a Huawei MA5300 DSLAM on the adsl 0/0/1 interface.
On the other and, I have a isc-dhcp-server connected to the DSLAM on ethernet 7/2/3.
Both adsl 0/0/1 and ethernet 7/2/3 are part of the smartVLAN101 on the DSLAM.
adsl0/0/1 is configured as a downport and eth7/2/3 as the upport.
smartVLAN101 IP: 10.1.1.254 /24
DHCP IP : 10.1.1.253 /24
When I give the router a static address such as 10.1.1.1 it can ping VLAN101 at 10.1.1.254 and the DHCP at 10.1.1.253.
I would like the router to get an IP address from the DHCP.
You will find attached,
- a drawing of the actual layout
- the router 877 running-config
- the DSLAM MA5300 running-config
- the DHCP config
- the debug DHCP output of the router
- the output of the show DHCP-server 1 command on the DSLAM
As you can see, the router seems to send DHCP request through the right interface (ATM0) but the DSLAM do not receive them.
I've tried a lot of configurations based on what I found on the internet but none of them did the trick. So I decided to start back from this pretty basic config.
Any help would be much appreciated.
Regards.
9 Replies 9
on the Cisco, try to add the following:
ip forward-protocol udp bootpc
ip forward-protocol udp bootps
service dhcp
I'll have a look at the Huawei...
Hello Georg,
Thank you for your answer,
I will try that tomorrow and let you know as soon as possible.
Regards.
I'v tried the commands that you suggested, unfortunately nothing changed.
I still have the same DHCP debug on the router and still no paquets received on the DSLAM.
Any other ideas ?
Regards.
on the Huawei, it looks like you have option 82 enabled, can you try and disable that ?
Option82 is disabled, no changes.
Tomorrow I'll try to create a sub-interface ATM because ATM0 is not point-to-point from what I've read here.
I'll let you know.
Thank you for your time Georg.
I have configured an ATM0.1 point-to-point interface and added some ACLs on the router and on the adsl interface of the DSLAM. Still no DHCPREQUESTS received on the DSLAM.
So I decided to create a virtual interface Dialer0 but it still does not work and I have the same DHCP debug on the router exept that the broadcast is sent to Dialer0 and not ATM0 or ATM0.1 anymore.
I can post the ACL that I added if you want.
Those were my last ideas to make this work, I don't really know what to try now.
Any ideas would be welcomed ...
on the 877, try and globally configure:
service dhcp
Does that make a difference ?
What do you mean by "globally configure" ?
I did run this command in configuration mode but it did not work.
I used a pppoe server to get dynamic IP address.
Here is the link to the post : https://supportforums.cisco.com/discussion/13304601/ppp-over-atm-not-working-cisco-877
Problem solved.
