dialer if problem
a.hajhamad
Level 4
Level 4
i have the following configuration:
controller SHDSL 0/0/0
dsl-group 0 pairs  0,1
  shdsl annex A
shdsl rate auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface Virtual-Template1
no ip address
interface Dialer1
mtu 1492
ip mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication pap callin
ppp pap sent-username 'username' password 0 'password'
the controller interface is UP and i got the following PPP error while debug:
Vi2 PAP: I AUTH-NAK id 2 len 26 msg is "Authentication failed"
the username and password are correct.
IOS: c2800nn-entbasek9-mz.151-1.t3.bin
any ideas?
thanks in advance
do you use RADIUS authentication server? what does it say in log?
activate additional debaug "ppp authen" "ppp negotia" "aaa authent"
but your error is quite obvious - you have username/password problems. check if you don't have any "space" characters in password or somwthing like this.
Thank you for your response.
Yes, the problem is solved by the ISP since we upgraded the line from 2 Mbps to 4 Mbps (new line), it needs a reset by the ISP since it logged the old physical interface ID (2 Mbps).
Thanks again
