07-25-2006 05:06 AM - edited 03-03-2019 01:26 PM
Could someone please remind me of the difference between these two mechanisms and how I would be able to determine which I had to configure ?
Cheers,
Marcel
Solved! Go to Solution.
07-27-2006 07:41 PM
07-25-2006 03:20 PM
CAR is the policing function that was originally implemened in IOS. With the advent of class-based policing, you have much greater flexibility in defining the traffic you want policed.
I would only use CAR if I were using an older IOS version that did not support class-based policing (CB policing). IF you have a choice, go for CB policing.
Paresh
07-27-2006 07:41 PM
07-28-2006 12:37 AM
Yes, it certainly was!
Thanks!
