Difference between IOS vs NX-OS NAT Order of Operation
rhayashi5
Dear all,
I plan to use NX-OS N9k such as C93148GC-FXP and C93180YC-EX. (not ACI)
I have a concern Processing order of traffic when using NAT
Please look at follouwing URL.
IOS NAT Order of Operation is Listed.
[NAT Order of Operation]
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/6209-5.html
Inside-to-Outside        Outside-to-Inside
  • If IPSec then check input access list
  • decryption - for CET (Cisco Encryption Technology) or IPSec
  • check input access list
  • check input rate limits
  • input accounting
  • redirect to web cache
  • policy routing
  • routing
  • NAT inside to outside (local to global translation)
  • crypto (check map and mark for encryption)
  • check output access list
  • inspect (Context-based Access Control (CBAC))
  • TCP intercept
  • encryption
  • Queueing
  • decryption - for CET or IPSec
  • input accounting
  • NAT outside to inside (global to local translation)
  • policy routing
  • routing
  • inspect CBAC
  • TCP intercept
  • encryption
  • Queueing
Even if NX-OS, Is the packet processing order same?
Best Regards,
Ryunosuke Hayashi
0 Replies 0
