Difference between Router QoS and Switch QoS
qasimkhans8
what is the Difference between Router QoS and Switch QoS? when we need Router QoS and when we need Switch QoS?
if I have VOIP QoS on router, then do i need VOIP QoS on Switch?
5 Replies 5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
That depends on the devices being compared.  Generally, router QoS offers many more QoS configuration options.
One doesn't depend on the other.  Both depend on whether there's congestion that's adverse to the service needs of the traffic (and whether QoS can meet those needs).
Ditto to prior question and answer.
" That depends on the devices being compared.  Generally, router QoS offers many more QoS configuration options. "
Does Router QoS for incoming and outgoing Internet RTP traffic and Switch QoS for LAN RTP traffic?
If there is not congestion  on Internet and LAN then Router and Switch will not prioritize RTP taffic?
Sorry, I'm not sure what you're asking.
Correct.  If there's no congestion there's nothing to prioritize.
Don't confuse actual prioritization with tagging packets that should be prioritized.  They often go together, but they don't have to.
QoS on Router for Internet incoming/ougoing traffic only?
QoS on Switch for LAN incoming/ougoing traffic?
QoS features vary between platforms, especially between routers and switches, and vary between ingress and egress interfaces, but device doesn't know or care what the port is connected to.
