Different MTU size's in a single ping command
Ahmed Mukhtar
Hello
I have a question which may sound silly...But if i want to ping any ip say i want to ping 1.1.1.1....so can i ping it with Multtiple MTU sizes???
like when i hit the command
Rx# ping 1.1.1.1
Then can i make each ping go with a different a Different MTU size if i want ??? by any command or something??
I want the output to be something like this....
Means each ping Goes with a different Byte Size or MTU size....
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=64 time=2ms TTL=64
Reply from 192.168.1.1: bytes=100 time=2ms TTL=64
Reply from 192.168.1.1: bytes=150 time=7ms TTL=64
Its just an example i took but it clears the concept i think
can this be done??
Thank you
cadet alain
altough it is a duplicate post I'll reiterate my first answer: extended ping !
here's an example
R1(config)#do ping
Protocol [ip]:
Target IP address: 10.0.0.2
Repeat count [5]: 1
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]: y
Sweep min size [36]: 80
Sweep max size [18024]: 90
Sweep interval [1]: 5
Sending 3, [80..90]-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 100 percent (3/3), round-trip min/avg/max = 24/33/44 ms
R1(config)#
*Mar  1 00:03:05.671: IP: tableid=0, s=10.0.0.1 (local), d=10.0.0.2 (FastEthernet0/0), routed via FIB
*Mar  1 00:03:05.675: IP: s=10.0.0.1 (local), d=10.0.0.2 (FastEthernet0/0), len 80, sending
*Mar  1 00:03:05.675:     ICMP type=8, code=0
*Mar  1 00:03:05.715: IP: tableid=0, s=10.0.0.2 (FastEthernet0/0), d=10.0.0.1 (FastEthernet0/0), routed via RIB
*Mar  1 00:03:05.715: IP: s=10.0.0.2 (FastEthernet0/0), d=10.0.0.1 (FastEthernet0/0), len 80, rcvd 3
*Mar  1 00:03:05.715:     ICMP type=0, code=0
*Mar  1 00:03:05.719: IP: tableid=0, s=10.0.0.1 (local), d=10.0.0.2 (FastEthernet0/0), routed via FIB
*Mar  1 00:03:05.719: IP: s=10.0.0.1 (local), d=10.0.0.2 (FastEthernet0/0), len 85, sending
*Mar  1 00:03:05.723:     ICMP type=8, code=0
*Mar  1 00:03:05.747: IP: tableid=0, s=10.0.0.2 (FastEthernet0/0), d=10.0.0.1 (FastEthernet0/0), routed via RIB
*Mar  1 00:03:05.751: IP: s=10.0.0.2 (FastEthernet0/0), d=10.0.0.1 (FastEthernet0/0), len 85, rcvd 3
*Mar  1 00:03:05.751:     ICMP type=0, code=0
*Mar  1 00:03:05.751: IP: tableid=0, s=10.0.0.1 (local), d=10.0.0.2 (FastEthernet0/0), routed via FIB
*Mar  1 00:03:05.755: IP: s=10.0.0.1 (local), d=10.0.0.2 (FastEthernet0/0), len 90, sending
*Mar  1 00:03:05.755:     ICMP type=8, code=0
*Mar  1 00:03:05.775: IP: tableid=0, s=10.0.0.2 (FastEthernet0/0), d=10.0.0.1 (FastEthernet0/0), routed via RIB
*Mar  1 00:03:05.775: IP: s=10.0.0.2 (FastEthernet0/0), d=10.0.0.1 (FastEthernet0/0), len 90, rcvd 3
*Mar  1 00:03:05.775:     ICMP type=0, code=0
Alain
cadet alain
here's an example
R1(config)#do ping
Protocol [ip]:
Repeat count [5]: 1
R1(config)#
Alain
Excellent!!! Thats what i wanted to know! Thank u and sorry for the duplicate Post But thank u so much sir!
