difficulty in re-installing ios on cisco 2821
AlfredNketia
I'm  trying to install ios into my  cisco 2821 which boots in rommon.  Apparently the ios is corrupted, I  have set the IP_ADDRESS,  IP_SUBNET_MASK, DEFAULT_GATEWAY, TFTP_SERVER,  TFTP_FILE but anytime I  issue the 'tftpdnld' and confirm to continue,  the process will time out  give this error message
ARP: address resolution for 10.203.8.49 timed out.
ARP failed with failure code 1.  TFTP transfer aborted.
TFTP: Operation terminated prematurely.    "
What may have gone wrong. Please help me out.
6 Replies 6
vmiller
Level 7
Level 7
If you aren't on the same subnet, you will need an ip helper address.
ip helper-address
To have the Cisco IOS software forward User Datagram Protocol  (UDP) broadcasts, including BOOTP, received on an interface, use the ip helper-address interface configuration command. To  disable the forwarding of broadcast packets to specific addresses, use the no form of this command.
ip helper-address address
no ip  helper-address address
Syntax Description
address
Destination broadcast or host address to be used when  forwarding UDP broadcasts. There can be more than one helper address per  interface.
Defaults
Disabled
Command Modes
Interface configuration
Command History
Release
Modification
10.0
This command was introduced.
Usage Guidelines
Combined with the ip forward-protocol global configuration command, the ip helper-address command allows you to control which  broadcast packets and which protocols are forwarded.
One common application that requires helper addresses is  Dynamic Host Configuration Protocol (DHCP), which is defined in RFC 1531. DHCP  protocol information is carried inside of BOOTP packets. To enable BOOTP  broadcast forwarding for a set of clients, configure a helper address on the  router interface closest to the client. The helper address should specify the  address of the DHCP server. If you have multiple servers, you can configure one  helper address for each server. Because BOOTP packets are forwarded by default,  DHCP information can now be forwarded by the router. The DHCP server now  receives broadcasts from the DHCP clients.
All of the following conditions must be met in order for a  UDP or IP packet to be helpered by the ip helper-address command:
The MAC address  of the received frame must be all-ones broadcast address (ffff.ffff.ffff).
The IP  destination address must be one of the following: all-ones broadcast  (255.255.255.255), subnet broadcast for the receiving interface; or major-net  broadcast for the receiving interface if the no ip classless command is also configured.
The IP  time-to-live (TTL) value must be at least 2.
The IP protocol  must be UDP (17).
The UDP  destination port must be for TFTP, Domain Name System (DNS), Time, NetBIOS, ND,  BOOTP or DHCP packet, or a UDP port specified by the ip  forward-protocol udp global configuration command.
Note The ip helper-address command does not work on an X.25  interface on a destination router because the router cannot determine if the  packet was intended as a physical broadcast.
Examples
The following example defines an address that acts as a  helper address:
interface ethernet 1
 ip helper-address 121.24.43.2
Related Commands
Command
Description
ip  forward-protocol
Specifies which protocols and ports the router forwards when  forwarding broadcast packets.
Richard Burts
vmiller
You have provided nice and helpful information about the ip helper-address command. But the post from Alfred was pretty clear that his router was booting into rommon. And the ip helper-address does not operate in rommon.
Alfred
The output that you give us includes this:
"ARP: address resolution for 10.203.8.49 timed out."
So it is pretty clear that the router has attempted to ARP which means that it things that the destination address is in the local subnet. So perhaps it would help us to understand what is the issue if you could provide specifics for the values of IP_ADDRESS, IP_SUBNET_MASK, DEFAULT_GATEWAY, and TFTP_SERVER.  The easy way to do this is to cut and paste the output of the set command.
Given the error message that ARP resolution timed out there are a couple of possible explanations:
- the router believes that the TFTP server is on the local subnet but it is not.
- the router is ARPing for its gateway but the gateway is not responding - perhaps because the gateway address is not correct.
Rick
Rick
Hi Rick,
As requested these are the settings on the router.
IP_ADDRESS: 10.203.8.138
      IP_SUBNET_MASK: 255.255.255.0
     DEFAULT_GATEWAY: 10.203.8.250
         TFTP_SERVER: 10.203.8.49
           TFTP_FILE: c2800nm-advipservicesk9-mz.124-24.T.bin
        TFTP_VERBOSE: Progress
    TFTP_RETRY_COUNT: 18
        TFTP_TIMEOUT: 7200
       TFTP_CHECKSUM: Yes
        TFTP_MACADDR: 00:1e:be:01:44:60
             GE_PORT: Gigabit Ethernet 0
       GE_SPEED_MODE: Auto
command for disaster recovery only.
rommon 13 >  existing data in all partitions on flash: will be lost!
rommon 13 > to continue? y/n:  [n]:  y
rommon 13 >
rommon 13 >  resolution for 10.203.8.49 timed out.
rommon 13 > ith failure code 1.  TFTP transfer aborted.
rommon 13 >
rommon 13 > ion terminated prematurely.
Looking forward to getting your help. Thanks
Alf.
Alf
Thanks for the additional information. It does help to clarify what is happening. Clearly the router is attempting to arp for the tftp server and the arp is failing. At the risk of asking the obvious here are a couple of questions:
- can you verify that the tftp server is active and that its address is 10.203.8.49?
- can you verify that the tftp server is connected to the router on the router interface Gig0?
Rick
Rick
Alfred posted this same issue in the Network Management forum where it got an interesting response today. I suggest that all further discussion of this issue be consolidated in the Network Management forum using this URL:
https://supportforums.cisco.com/thread/2077726?tstart=0
Rick
Rick
Leo Laohoo
Hey Alfred,
Any ideas why you want to make multiple posts of this same thread?
Anyway ... in one of the threads you created, I asked why not use a media card reader.
