DMVPN EIGRP Spokes not forming dynamically with eachother
hfakoor222
Just doing lab, cannot get DMVPN spoke to spoke communication, 1 hub , 2 spokes,
I tried shutting the tunnels down/up didn't work
interface Tunnel0
no ip redirects
ip mtu 1400
ip nhrp authentication ccnp
ip nhrp map 192.168.1.254 10.10.255.254
ip nhrp map multicast 10.10.255.254
ip nhrp network-id 1
ip nhrp holdtime 300
ip nhrp nhs 192.168.1.254
ip nhrp shortcut
ip tcp adjust-mss 1360
tunnel source Ethernet0/1
tunnel mode gre multipoint
tunnel key 100
tunnel protection ipsec profile abcd
Spoke 2:
crypto isakmp policy 5
hash md5
authentication pre-share
crypto isakmp key cisco address 0.0.0.0
crypto ipsec transform-set ccnp esp-3des
mode transport
crypto ipsec df-bit clear
crypto ipsec profile abcd
set transform-set ccnp
interface Tunnel0
ip address 192.168.1.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp shortcut
tunnel key 100
show dmvpn:
I thought gre multipoint wouldve made spoke to spoke communication OK
Debug of smvpn all all /errors/ packets on Spoke #1 shows no issue. The tunnels simply aren't communicati
*ng
7 Replies 7
Can I see
Show ip dmvpn details
MHM
hfakoor222
Interestingly enough I got it to work after trying to force pinging the other side of the tunnel......
Notice it was ARPing
Sure if there is no interest traffic there is no Dynamic tunnel between two spokes.
The config is OK.
MHM
Hello @hfakoor222 ,
verify on the HUB router mGRE tunnel interface that you have
no ip eigrp <ASN> next-hop self
Your Spoke1, Spoke2 tunnel config looks like fine.
Hope to help
Giuseppe
I 100% sure I see this command and no IP split in his config
@hfakoor222 did you change config?...?
MHM
hfakoor222
I'm redoing the lab just to make sure. I figured the ping acted like an nhrp registration for other side of tunnel.
This way you can not know you need to go deep
Return to your first config (include no split and no next hop)
WR config
Close the lab and open again (to remove all crypto and route add)
Do this command
Debug nhrp packet  <- in spokes and hub
Ping from Lan to Lan of spokes
Know you will see redirect and shortcut nhrp message
MHM
