DMVPN IPsec error message: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet.
cedar_lee
Wondering if anyone saw the following IPsec error message from DMVPN Hub routers? (172.19.72.1 is a loopback address used as the source of a DMVPN tunnel)
%CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= vrf-dmvpn/172.19.72.1, src_addr= 0.0.0.0, prot= 47
Not sure why it shows "src_addr= 0.0.0.0" and how to fix this issue.
Cedar
Hello
Can you post your tunnel and ipsec  configuration?
res
Paul
Kind Regards
Paul
Hi Paul,
My colleague figured out it's caused by a spoke with tunnel interface link protocol down. This error message on the hubs stopped after this tunnel interface got shut down on the spoke router. We will upgrade the software version of this router and check again.
Cedar
