DMVPN ping time increase
brinkeja151
I have set up a DMVPN between 3 sites. I can connect to resources in all location without issue. Ping times run around 45ms. However, when I attempt to view a Video server in my remote data center or if I attempt to register a phone over the tunnel, my Ping times jump to 2000ms. I don't have any traffic on this tunnel except either the Video server or 1 phone so there should not be a bandwidth or traffic problem. Please advise.
Hub config
interface Tunnel0
description HUB
bandwidth 2000
ip address 10.151.151.1 255.255.255.248
no ip redirects
ip mtu 1400
ip nhrp authentication *****
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 360
ip tcp adjust-mss 1360
delay 1000
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key XXXXXX
tunnel protection ipsec profile *****
Spoke
interface Tunnel0
description SPOKE1
bandwidth 2000
ip address 10.151.151.2 255.255.255.248
no ip redirects
ip mtu 1400
ip nhrp map 10.151.151.1 68.X.X.X
ip nhrp map multicast 68.X.X.X
ip nhrp nhs 10.151.151.1
delay 1000
tunnel source GigabitEthernet0/1
tunnel key XXXXXX
Giuseppe Larosa
Hello Jason,
icmp packets are not processed with high priority by the routers.
I would check the cpu usage on both routers during the video streaming, the huge increase in ping RTT could be caused by high cpu usage in one router.
Hope to help
Giuseppe
