DMVPN: traffic between two DMVPN's fails when adding ipsec
cpdev
Hello Colleagues,
this is our setup (of cause a bit cleaned up):
we configured a Hub and spoke DMVPN with MPLS, OSPF and BGP.
R6-R5(WAN/Tun1) forms a DMVPN and R8-R5(LAN/Tun2) forms a second DMVPN.
DMVPN comes up and we are able to ping each router and resources in the networks behind R3.
Routing appears to be correct.
Now we want to encrypt the WAN traffic via Tun1.
Once we apply IPSEC ikev2 profile on the DMVPN  WAN (Tun1)  traffic flow from DMVPN WAN Spoke R6 to DMVPN LAN Spoke R8 (e.g. a PING) stops and MPLS shows a strange behaviour (e.g. R3 loopback not reachable any more).
Nonetheless, as far as we tested any other resource is still reachable.
Spokes - R6 Config
interface Tunnel1
 description DMVPN-WAN
 bandwidth 1000000
 bandwidth inherit 1000000
 ip address 10.253.253.99 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip flow ingress
 ip pim sparse-mode
 ip nhrp authentication GSN-IT
 ip nhrp map multicast dynamic
 ip nhrp map multicast <WANIP>
 ip nhrp map 10.253.253.1 <WANIP>
 ip nhrp network-id 1
 ip nhrp holdtime 10
 ip nhrp nhs 10.253.253.1 priority 1 cluster 1
 ip nhrp nhs fallback 5
 ip nhrp registration timeout 5
 ip tcp adjust-mss 1360
 ip ospf network point-to-multipoint
 ip ospf 1 area 0
 mpls traffic-eng tunnels
 mpls bgp forwarding
 mpls ip
 keepalive 10 3
 cdp enable
 tunnel source Dialer1
 tunnel mode gre multipoint
 tunnel path-mtu-discovery
 tunnel bandwidth transmit 1000000
 tunnel bandwidth receive 1000000
tunnel protection ipsec profile test1_ipsec_prof end
crypto ikev2 proposal test1_proposal
encryption aes-cbc-256 aes-cbc-128 3des
integrity sha1
group 2
crypto ikev2 policy test1_ikev2-Policy
crypto ikev2 keyring test1_keyr
peer DMVPN
address 0.0.0.0 0.0.0.0
pre-shared-key cisco123
crypto ikev2 profile test1_prof_ikev2
match fvrf any
match identity remote any
authentication local pre-share
authentication remote pre-share
keyring local test1_keyr
dpd 60 2 on-demand
crypto ipsec transform-set AES256 esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec fragmentation after-encryption
crypto ipsec profile test1_ipsec_prof
set transform-set AES256
set ikev2-profile test1_prof_ikev2
 Hub- R6 Config:
interface Tunnel1
 bandwidth 1000000
 ip address 10.253.253.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip pim sparse-mode
 ip nhrp authentication <name>
 ip nhrp holdtime 600
ip tcp adjust-mss 1360 ip ospf network point-to-multipoint ip ospf 1 area 0 mpls ip mpls traffic-eng tunnels mpls bgp forwarding cdp enable tunnel source Loopback100 tunnel mode gre multipoint tunnel path-mtu-discovery tunnel vrf WAN
tunnel protection ipsec profile test1_ipsec_prof crypto engine slot 2/0 inside end
interface Tunnel2
description DMVPN-LAN
bandwidth 1000000
ip address 10.253.254.1 255.255.255.0
no ip redirects
ip mtu 1440
ip pim sparse-mode
ip nhrp authentication <ommit>
ip nhrp network-id 100
ip ospf 1 area 0
ip ospf cost 10
mpls ip
mpls bgp forwarding
cdp enable
tunnel source Loopback2
tunnel vrf LAN
end
integrity sha1
group 2
match fvrf WAN
peer DMVPN
match fvrf WAN
dpd 60 2 on-demand
crypto engine mode vrf
crypto engine gre supervisor
mode transport
ip vrf WAN
description WAN
rd 65001:10
route-target export 65001:10
route-target import 65001:10
ip vrf LAN
rd 65001:100
We are working on this issue since a few days. So maybe we miss the forest for the trees...
Thanks for your help.
PS: attached a snapshot of the used HW and IOS.
11 Replies 11
at first glance it looks like the tunnel on your hub has no ipsec protection configured. Add the line in bold to your tunnel config:
HUB-R6
interface Tunnel1
description DMVPN01
bandwidth 1000000
no ip redirects
ip mtu 1400
ip pim sparse-mode
ip ospf 1 area 0
mpls ip
mpls bgp forwarding
cdp enable
tunnel vrf WAN
Hi George,
you are right, but its "only" a copy and paste error (I correct it in the post).
right now ipsec is off due to the connectivity issues.
Hello
Just like to ask  - when you mean spoke to spoke - are you saying prior to any IPsec being added you had spoke to spoke phase 2 connectivity- meaning traffic between R6-R8 bypassed the NHS of R5
Now looking at the ospf network type you’ve applied any routes advertised from either of these spokes in ospf would have the point nexthop if the Nhs and not itself?  - So you would not have proper phase two spoke-to spoke reachability
To rectify this you would need to use either a broadcast or non broadcast ospf  network type which will allow the advertisement of the originating rtr IP address  to be the nexthop and not the NHS
res
Paul
Kind Regards
Paul
Hi Paul,
we will check that and report back.
Thanks.
cpdev
I updated the post above to give a more detailed explanantion.
So far its not a routing issue.
I am in the process of recreating your setup in GNS3. Can you post the full config of your hub and one of the spoke routers ?
I managed to have full connectivity using your IKEv2/IPSec configs, but with both spokes mapped to the same tunnel on the hub. So I suspect that is where your problem is, the two different tunnels on the hub.
Post the full configs of all (4) routers involved. Without seeing the details it is just guesswork...
Hi George,
attached the router configs... the 4th is in this case only for showing that there is more behind and not only two spokes and a Hub..
Thanks for the configs, I'll adjust my lab. I won't have any results until tomorrow, I am on GMT+1, which means it is almost midnight...:)
after adjusting my lab, my connections are working using IPSec and IKEv2 exactly as you have configured it. Below is the output of 'sh crypto session'...does yours look similar (actually, post the output of this command from your hub)...
HUB#sh crypto session
Crypto session current status
Interface: Tunnel0
Profile: IKEV2_PROFILE
Session status: UP-ACTIVE
Peer: 192.168.12.2 port 500
Session ID: 3
IKEv2 SA: local 192.168.0.2/500 remote 192.168.12.2/500 Active
IPSEC FLOW: permit 47 host 192.168.0.2 host 192.168.12.2
Active SAs: 2, origin: crypto map
Interface: Tunnel0
Peer: 192.168.11.2 port 500
Session ID: 2
IKEv2 SA: local 192.168.0.2/500 remote 192.168.11.2/500 Active
IPSEC FLOW: permit 47 host 192.168.0.2 host 192.168.11.2
Interface: Tunnel0
Peer: 192.168.13.2 port 500
Session ID: 1
IKEv2 SA: local 192.168.0.2/500 remote 192.168.13.2/500 Active
IPSEC FLOW: permit 47 host 192.168.0.2 host 192.168.13.2
Hello Georg,
Sorry for the late answer.
In the meantime we introduced a second WAN Spoke to analyze if the topic is related to IOS or Hardware IOS combination. See below
From the HUB:
Interface: Tunnel1
Profile: test1_prof_ikev2
Peer: WAN-ip-Spoke_1 port 500
Session ID: 71
IKEv2 SA: local local-wan-ip/500 remote WAN-ip-Spoke_1/500 Active
IPSEC FLOW: permit 47 host local-wan-ip host WAN-ip-Spoke_1
Interface: Tunnel1
Peer: WAN-ip-Spoke_2 port 500
Session ID: 49
IKEv2 SA: local local-wan-ip/500 remote WAN-ip-Spoke_2/500 Active
IPSEC FLOW: permit 47 host local-wan-ip WAN-ip-Spoke_2
HUB#sh cry ip sa
interface: Tunnel1
Crypto map tag: Tunnel1-head-0, local addr <local-wan-ip>
protected vrf: (none)
local ident (addr/mask/prot/port): (local-wan-ip/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (WAN-ip-Spoke_2/255.255.255.255/47/0)
current_peer WAN-ip-Spoke_2 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 14393, #pkts encrypt: 14393, #pkts digest: 14393
#pkts decaps: 19441, #pkts decrypt: 19441, #pkts verify: 19441
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: local-wan-ip, remote crypto endpt.: WAN-ip-Spoke_2
plaintext mtu 1458, path mtu 1500, ip mtu 1500, ip mtu idb (none)
current outbound spi: 0xC89EEDCF(3365858767)
PFS (Y/N): N, DH group: none
inbound esp sas:
spi: 0xE2C16B82(3804326786)
transform: esp-256-aes esp-sha-hmac ,
in use settings ={Transport, }
conn id: 2114, flow_id: :114, sibling_flags 80000008, crypto map: Tunnel1-head-0
sa timing: remaining key lifetime (k/sec): (4605732/1081)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2113, flow_id: :113, sibling_flags 80000008, crypto map: Tunnel1-head-0
sa timing: remaining key lifetime (k/sec): (4605772/1081)
IV size: 16 bytes
