DMVPN with dual tunnel and dual interfaces on hub router
doug_3002
I have a hub router that with 3 interfaces.
int 1 is used for DMVPN and so is int 3.  They are also used for IPSec RA VPN. webvpn, and port forwarding to inside servers.
int 2 is used for internet traffic.
I used VRF's to seperate int 1 and int 3 in the passed but i had issues.  So that I didnt have use inter VRF routing to solve it, i removed the VRF's and used static routes to reach the spokes for interface 1 and interface 3.  This is ok, because all the spokes use static IP's.
The spoke also have two tunnels and is sharing the ipsec profile as so:
int tun 1
tunnel protection ipsec profile PROFILE shared
int tun 2
The Circuit for WAN int 3 was not in yet so that interface is down.  I had issues with phase 1 and got the following debug error:
isakmp:(6803):key not found in keyrings of profile , aborting exchange
My understanding is that it was using the key, for keyring 2 and not for keyring 1...even though they are the same key.
When i removed the configs for keyring 2, phase 1 came online.
My question is, will i have issues when once the second WAN interface come online?  should i change the preshared key in keyring 2?
Hello.
Please share your configuration on the hub router and all the debug output you gathered.
I would say, that the solution with 2 VRFs was much better, than static routes. I think if you revert the configuration back to VRF, it should work fine.
I was having issues with routing and didnt want to configure inter VRF routing to communicate between the two sites.  I dont think it will work without inter VRF routing with BGP, and i didnt want to configure that.
Hello.
If you are using both Internet links as DMVPN transport only, then there is no need for routing between them.
Could you share your [previous] configuration with VRFs?
PS: if you want an answer for the question, I think [current] running configuration is needed here.
