Cisco C887VA VDSL Client Configuration Issue
eyalzafrani
hey i just configured my router .
The vdsl configuration is working and i have successed to config the pppoe.
i can also ping from my router to 8.8.8.8 and i have dns resolve.
the problem is thats my clients dont success to ping 8.8.8.8 or to recive dns resolve.
what am i miss?
ip dhcp excluded-address 10.0.0.138
ip dhcp pool NET-POOL
 network 10.0.0.0 255.255.255.0
 default-router 10.0.0.138
 dns-server 8.8.8.8 8.8.4.4
 lease 9
ip cef
no ipv6 cef
controller VDSL 0
ip ssh authentication-retries 5
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no ip route-cache
 loopback
 shutdown
 no atm ilmi-keepalive
interface Ethernet0
 no ip address
 no ip route-cache
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface FastEthernet0
 no ip address
 no cdp enable
interface FastEthernet1
 no ip address
 no cdp enable
interface FastEthernet2
 no ip address
 no cdp enable
interface FastEthernet3
 no ip address
 no cdp enable
interface Vlan1
 ip address 10.0.0.138 255.255.255.0
 no ip redirects
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1412
interface Dialer0
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 0
 dialer persistent
 dialer-group 1
 ppp pap sent-username ******** password 0 *******
 ppp ipcp dns request
 ppp ipcp mask request
 no cdp enable
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended EXTNAT
 permit ip any any
ip access-list extended extant
 permit ip any any
no service-routing capabilities-manager
dialer-list 1 protocol ip permit
no cdp run
access-list 100 permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 exec-timeout 0 0
 no modem enable
line aux 0
line vty 0 4
 privilege level 15
 password **********
 transport input all
scheduler allocate 20000 1000
end
Thanks alot.!
ghostinthenet
Level 7
Level 7
You're missing a NAT definition in your configuration. The interfaces are appropriately set up with "ip nat inside" and "ip nat outside" but you don't have anything telling the router what to do with these. Try adding the following lines and see if that helps you out.
ip access-list extended ACL_NAT
 permit ip 10.0.0.0 0.0.0.255 any
ip nat inside source list ACL_NAT interface Dialer0 overload
interface Dialer0
 ip mtu 1492
 ip tcp adjust-mss 1452
The interface settings at the end of that aren't strictly necessary for basic connectivity, but will help non-fragmenting applications to deal with the smaller MTU that your connection uses.
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
ghostinthenet
Level 7
Level 7
interface Dialer0
 ip mtu 1492
Thanks alot!
thats fixed my problem :)
