DNS SERVER with public IP behind the router
alaeldien
helloo
i want my DNS server to be accessible to the internet , ok i have poll of pulic ip address, and i have the router with serial interface configured with another public ip ,
i want to assign my server one of those public ip
should i configured the lan interface with one of them and the server with another in-same-subnet ip address
or what to do
how to overcome such scenario
thanks
Jon Marshall
ip nat inside source static
then on the router inside interface
int fa0/0
ip nat inside
int s0/0
ip nat outside
Edit - actually with NAT it may not be as easy as that. What addresses will the DNS server be handing out - you need to make sure it hands out public IP addresses for any requests from the Internet. It's no good handing out private IP addresses as these won't be reachable.
Jon
hello
the confusion is that how to map static route using 2 public ip
is it going to work this way ?
ip nat inside source static tcp 53 53
or ineed to create DMZ in the router if yes could you possibly please advise.
thank you
Alaa
i
Alaa
Okay you've confused me now. Why do you need to use the serial interface address in your nat statment ?
What is the IP address of your DNS server currently ?
Jon
