Does C921-4P Router Support Mobile IP Protocol
devgontejinder
Hi ,
I have bought a C921-4P router with IP Base License , but i come to know it does not support Mobile IP Protocol. Commands for Mobile IP configuration such as given below are not working.
ip mobile home-agent
ip mobile virtual-network 10.0.0.0 255.255.0.0
ip mobile host 10.0.0.1 10.0.254.254 virtual-network 10.0.0.0 255.255.0.0
ip mobile secure host 10.0.0.1 10.0.254.254 spi 100 key hex 123456789abcdef0123456789abcdef0 algorithm hmac-md5
MY QUESTION:
1. Does C921-4P (ISR 900 Series Router) Support Mobile IP protocol or feature at all or Not ?
2. If Yes (it support Mobile IP), Which license should i Buy ? (is "SL-900-APP=" License is Correct) ?
Any help will be appreciated.
Tejinder
devgontejinder
Does APPX license Activate Enterprise Features on Router ? Which generally consist of Layer-3 Protocol. So should i assume that Mobile IP feature will be present in "SL-900-APP=" as Mobile IP is Layer-3 Protocol ?
This is only last Assumption to me before Buying the License.
Please Clarify ?
Tejinder
