Does Cisco 2960-tcl support SSH
okoroji80
Cisco 2960 Optimization
The current software version is as follows:
System image file is "flash:c2960-lanbase-mz.122-35.SE5/
I WOULD LIKE TO KNOW THE UPGRADE PART TO BE ABLE TO ACCOMMPLISH THE FOLLOWING:
1. Deploy IOS Code containing Crypto ( K9 Image) features and reload the device with the new IOS
2. Generate RSA KEY on the network device + domain name.
3.set limit per MAC@to 4
4.set port to be protected instead of shutdown when limit exceeded
5.enable err disable recovery for link-flap events
6. set up required limits for port security settings preserving current NOD exception
7. i would like to know if i need to upgrade the IOS to achieve this. ?
I look forward to your response.
Jude.
Collin Clark
Check the feature navigator. It will tell you what IOS supports what feature.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
