Does recommended IPBase IOS image for 2851 support OSPF?
DAVID CRAWFORD
We have a number of old 2851 ISRs running IOS 12.  I'd like to upgrade to IOS 15, but I only have 256 MB of RAM, so I can't run the c2800nm-advipservicesk9-mz.151-4.M12a.bin image.
The configuration is simple, but I do need OSPF.  Does c2800nm-ipbasek9-mz.151-4.M12a.bin support OSPF?
BTW, I tried to get this information on the software download page on the Cisco site but no information was returned by the "View Software Features" query.  I also tried opening a TAC case but was unsuccessful because the units are no longer under support.
Dave Crawford
Senior Systems Engineer
Paul Hastings LLP
Hello Paul,
yes, OSPF is supported in the IP Base release (15.x).
You can use the Feature Navigator to check which features are available in which release, by the way.
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Hello Paul,
