Does the 3745 1FE2W Module Support MPLS?
wpalumbo06
I have a couple of these routers in the lab with a very basic MPLS configuration on them.  Everything works fine on the fixed interfaces but I cannot get the ldp neighborship to form between the 1FE2W interfaces on each router.  Does this module support MPLS?
Thanks...
Peter Paluch
I do not know for sure about this module. Then again, for these routers, the MPLS is a software feature so a hardware Layer2 module should not be limited (or limiting) in any way.
One key thing to consider: the LDP chooses a Router ID much like the OSPF does. However, at least in Cisco implementation, the LDP actually uses this Router ID as a source/destination IP address in the LDP communication. This means that if a router has chosen a particular LDP RID, its neighbors must be able to resolve that RID in their routing tables, otherwise, the neighbors won't be able to start a LDP adjacency.
I suggest using the mpls ldp router-id force command to make sure that the LDP RID is set to a particular interface's IP address, and then making sure that this IP address is advertised to other routers via a routing protocol.
Best regards,
Peter
I agree that interface should not matter but it's the only thing different in the configuration.  I'll try forcing the router ID and see what that does.
Thanks...
Well...I decided to blow away both router configs and rebuild them
from scratch...everything works fine now.  I must have configured something wrong the first time but I can't imagine what - configuring MPLS between two routers isn't exactly rocket science...or isit:-)
Thanks again.
