Does the input/output rate of the interface take into account the Interframe Gap and preamble?
mrisler.ig
Hi Team,
So that is my question. When i run a "show interface Gi x/x", does the below ouput consider the Interframe gap and preamble, or just start counting the bits from the layer 2?
5 minute input rate 47000 bits/sec, 90 packets/sec
  5 minute output rate 44000 bits/sec, 91 packets/sec
Thanks for your help!
Peter Paluch
In my best belief, these counters do not count Inter Frame Gap and preambles. If I may ask, what would be the purpose of taking these values into account?
Best regards,
Peter
eter,
Thanks very much for your reply! You are correct, it does not count inter frame gap and preamble. I just did a quick test with a JDSU Tester, a cisco switch ( WS-C3560G ) and a hard loop. When i configured CIR of 9.87 Mbps, on my loop i was receiving 10 Mbps of bandwidth ( Line speed Layer 1 ) and 9.87 Mbps of IR ( Layer 2). Then, i checked my interface`s input/output rate and saw the same result:
MIA-SW5#sh int gigabitEthernet 0/14 | i 30
  30 second input rate 9870000 bits/sec, 813 packets/sec
  30 second output rate 9870000 bits/sec, 813 packets/sec
I was trying to understand the tool iPerf and the bandwidth command on it. I actually think they may refer bandwidth to throughput ( Layer 3), because when i configured 2Mbps with MTU of 1500, i was expecting to see 2 Mbps on my switch`s interface, but i saw 2.15 Mbps aprox.
I will keep learning on how to use this tool.
Thanks for your reply!
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You might also find, L2 framing overhead isn't counted either.
